flashing codes #93+ #75--HELP!!
Old Jun 9, 2001 | 10:06 PM
scrap-iron's Avatar
I'm flashing code#93- "EVAP Canister Vent Control Valve" and Code#75 "Evap Control Sysytem" Does anyone know what I should do to rectify this problem--other than just reseting the ECU? PLease help.
Old Jun 9, 2001 | 10:28 PM
emax02's Avatar
In the future do a search before posting a question like this. I was nice enough to do a search for you and this is what Daniel B. Martin posted on a simular{maybe the same} problem.
Diagnostic Trouble Code 0903 points to a problem with the EVAP Canister Vent Control Valve. EVAP = EVAPorative emissions control system. This is the system which seeks to minimize air pollution which results from evaporation (as opposed to incomplete combustion) of gasoline.
The EVAP CVCV is located on the EVAP Canister (underneath the vehicle near the left rear tire) and is used to seal the Canister vent. It has one hose connection and one two-wire electrical connector. The solenoid in the EVAP CVCV responds to signals from the ECM. When the ECM sends an ON signal, the coil in the solenoid valve is energized. A plunger then moves to seal the Canister vent. The ability to seal the vent is a necessary part of the diagnosis algorithms for other evaporative loss system components. This solenoid valve is used only for diagnosis, and usually remains open. When the vent is closed, under normal purge conditions, the evaporative loss system is depressurized allowing "EVAP Control System (Small Leak)" diagnosis. Since this part is used only for brief emissions tests the vehicle will usually start and run well despite a Service Engine Soon warning light on the dashboard.
The EVAP CVCV may be bench tested. Remove it from the vehicle (one hose, one connector, two bolts). Verify that air may pass freely through the valve. Then use a pair of fused test leads to apply 12 volts to the terminals to energize the solenoid. Verify that air does not pass freely through the valve. If the CVCV fails these tests, try cleaning it with WD-40 and compressed air. If this fails to free it up, replace the valve. When you install a CVCV (the original or a replacement) always use a new O-ring.
Old Jun 10, 2001 | 10:28 AM
Daniel B. Martin's Avatar
DTC 0705
Diagnostic Trouble Code 0705 points to a problem with the Evaporative Emission Control System.
This malfunction is detected when the EVAP control system has a leak or the EVAP control system does not operate properly. (EVAP = EVAPorative emissions.)
Possible causes include...
- incorrect fuel tank vacuum relief valve
- incorrect fuel filler cap
- fuel filler cap vent remains open or fails to close
- foreign matter caught in fuel filler cap
- a leak in the line between the intake manifold and the
EVAP Canister Vacuum Control Valve
- foreign matter caught in the EVAP CVCV
- leaks in the EVAP canister or fuel tank
- leaks in the EVAP purge line (pipe and rubber tube)
- EVAP purge line rubber tube bent
- blocked or bent rubber tube to EVAP control system pressure sensor
- loose or disconnected rubber tube
- EVAP CVCV and circuit
- EVAP Canister Purge Volume Control Solenoid Valve and circuit
- absolute pressure sensor
- tank fuel temperature sensor
- MAP/BARO switch solenoid valve and circuit
- blocked or bent rubber tube to MAP/BARO switch solenoid valve
- O-ring of EVAP CVCV is missing or damaged
- water separator
- EVAP canister saturated with water
- EVAP control system pressure sensor
- refueling EVAP vapor cut valve
- ORVR system leaks
This is a "jackpot" code. It points to so many possible causes as to be almost useless. It may be accompanied by another DTC which is more specific.
Old Jun 10, 2001 | 10:32 AM
Learn how to use the Search Engine. It doesn't always work right, but is worth a try. That may get you the fastest answer to your question.
Diagnostic Trouble Codes are always four numbers and the first number is always 0 or 1. Therefore your two Codes are 0705 and 0903.
Old Jun 10, 2001 | 11:13 AM
Botos's Avatar
I actually just had my Max in for the same codes; it turned out the valve was seized with carbon, and the filter had fused to it. New valve and filter were about $60 each, plus an hour and a half of labor.
Old Jun 11, 2001 | 05:55 AM
Curt Deiner's Avatar
Yeah...I have this problem on my '97 SE 5-spd. The light went out once by itself, but now it's back on. I ordered a part from Courtesy Nissan, but they sent me one for a '96, which they said wouldn't work, so I sent it back. I still need to get over to my local dealer and pick one up. They quoted me about $60 for the part. Looks a little tight there. Did you locate it? It's right in front of the canister, behind the driver's side rear wheel. I think a pair of ramps are in my future. Are you going to do this yourself? Please post any helpful hints. btw, my car runs fine, and I've been kinda lazy taking care of this.
Old Jun 11, 2001 | 07:14 AM
Originally posted by Curt Deiner
... btw, my car runs fine, and I've been kinda lazy taking care of this.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
