Does Nissan sell me this part alone, instead of the whole strut mount?
Old Feb 14, 2006 | 08:54 PM
BigLou93SE's Avatar
Instead of buying the complete strut mount, the part that I need to replace due to cutting it off is the Strut Bracket, part number 53422-31U00, as listed on this SUSPENSION PAGE. I've tried searching two wholesaler dealer parts websites (Pinnacle and Courtesy), and none of them are showing results for just that part, however, I can see they sell the strut mount. What I need to replace is Part 3 in the pic below. I'm going to call tomorrow, but I was curious to see if anyone knew the deal with this part. If I did go ahead and buy the strut mount complete, will it include this bracket that I need, or no?
Old Feb 14, 2006 | 08:59 PM
BigLou93SE's Avatar
Forget it, I think I found the problem, that page lists an incorrect part number if I'm not mistaken.
Old Feb 15, 2006 | 03:31 AM
colinnwn's Avatar
part number 3
I'm trying to get to the magic 15 replies. So, even though you got it figured out, I'll reply anyway.
I haven't replaced that part on a Maxima, but I have replaced it on an Altima and they are sold individually. Expensive crap though, I think it was about $90. I do remember it was more than the strut I put on, even though its just a piece of metal with 3 studs stuck in it.
Old Feb 15, 2006 | 04:35 AM
MaximaSE96's Avatar
Maxima Owner
i am sure they will sell it but its not really part of the mount...atleast the KYBs its not
Old Feb 15, 2006 | 02:19 PM
dtrain73's Avatar
From what I am reading from your post, you need the part that has the three bolts which anchor the front strut mount. try this link. It is called the Bracket Back. http://www.nissanpart4u.com/oem_parts.html
Old Feb 15, 2006 | 02:32 PM
BigLou93SE's Avatar
The part actually shouldn't be more than $20 or so for this bracket with three studs on it. Anyways, as I said above, I found it...
Old Feb 15, 2006 | 02:33 PM
BigLou93SE's Avatar
That's what I asked in that other thread I posted, and someone said that it was a part of that. Man am I glad that I didn't buy those mounts thinking I was getting this bracket as well!! Oh well, courtesy Nissan sells them for 17.xx a pop, so I'm going with them. Hopefully shipping won't be too bad.
Old Feb 15, 2006 | 02:37 PM
PAREDLINE's Avatar
I'm sure nissan will sell you that one part for as much as you can get the entire assembly aftermarket. You'll also need the bearing. Its a little plastic donut and if you had to grind into the strut mount i'm sure you caused damage to the bearing.
Old Feb 15, 2006 | 02:41 PM
BigLou93SE's Avatar
I'm replacing the bearing regardless, but no damage will come to the strut mount itself, only the bracket that I am replacing. I need to cut the strut mounting nuts off.
On another note: Why wouldn't I need to replace the bearing anyways, if I'm replacing the suspension, Paredline? I was told to absolutely replace this bearing in my other thread
Old Feb 15, 2006 | 02:42 PM
PAREDLINE's Avatar
That bracket is part of the strut mount assembly. That was my point. By the time you add up the bracket plus the bearing, you'll probably spend as much as you would if you went and got the whole assembly from the parts store.
Old Feb 15, 2006 | 04:23 PM
BigLou93SE's Avatar
I see what you're saying now. I've heard that the part that I've been referring to doesn't come with the strut mount assembly...I don't know.
Old Feb 15, 2006 | 06:31 PM
njmaxseltd's Avatar
Part 2 and part 3 are sold as two seperate items.
Normally you only need part #2, the rubber mount for the strut shaft to bolt onto.
Old Feb 15, 2006 | 06:53 PM
JamesNH's Avatar
Part 3 is 54322-31U00
Part 2 for Se 5spd is 54320-40U00
vingodine
45
May 21, 2016 12:46 PM
MaxInfamy
Forced Induction
Aug 24, 2015 12:01 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
