Front Brake Rubbing Question
Old Feb 16, 2006 | 06:00 AM
Chris99SE's Avatar
What would cause my passenger front caliper bracket (the one that holds the pads) to rub against the rotor??? I had the problem last week, so this weekend i took it apart cleaned it and put it all back together. Now i hear it doing it again when i make a left turn. Has this happened to anyone else???? Thanks in advance.
Old Feb 16, 2006 | 06:11 AM
Mmmaxx's Avatar
Is the caliper jammed?
This happened to me once before, I was getting on the highway and decided to test the new suspension a bit so I went about 65 in the on ramp which was a pretty sharp curve. Anyway, half way through I had to hit the brake a bit, seconds later I heard the evilest noise ever. It was like the noisemaker when your breakpad is about done only like 50 times louder. Anyway, I freaked out and pulled over and went and checked and the caliper was still closed up, after a few pumps of the break it opened back up and has been fine since. Must have been something with the speed,turn, and brake amount I applied.
Anyway your sure its rubbing and its not just the pad maken noise? When you took it apart did you push the piston back out?
Old Feb 16, 2006 | 06:16 AM
Chris99SE's Avatar
I don't think its the caliper. When i took it apart, the top inside of the bracket was shiney where it was hitting the rotor. It is definitely a grinding noise and not a high pitched squeal.
Old Feb 17, 2006 | 05:23 AM
Chris99SE's Avatar
up to the top for a new day.
rbuswell
Nov 17, 2016 04:54 AM
03VQMAX
Sep 25, 2015 04:19 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
