Double Check: Am I missing something? suspension parts order.
Old Feb 17, 2006 | 11:50 AM
MDeezy's Avatar
This is a new SET SUSPENSION PARTS: 1 Lower Control Arm (Left) complete OE K9818L, 1 lower Control Arm (right) complete OE K9818R for Nissan Maxima 1995-99, Infiniti I30 94-99, includes bushings and ball joint, 2 Inner Tie rod end OE EV352, 2 Outer Tie rod end OE ES3438, 2 Sway bar link K90126
Replacing pretty much everything suspension wise in the front of my car. Am I missing any bushings? Just wanted to double check.
Thanks.
Old Feb 17, 2006 | 02:28 PM
dgeesaman's Avatar
Maintenance Monster
Well, out of what's listed there, you have most of the unsprung parts covered.
You might choose to add:
- engine support front bushings (not suspension exactly)
- engine support rear bushings (not suspension exactly)
- swaybar endlink bushings
- swaybar mount bushings
- strut mount
- strut boot
- strut tower bearing
There are also some bushings between the subframe and unibody that I'm curious about.
Dave
Old Feb 17, 2006 | 02:32 PM
DragonMaxima's Avatar
Mdeezy,
I was planning on doing this as well. Where are you purchasing these from and how much is it going to cost?
Old Feb 17, 2006 | 03:17 PM
Dubbya's Avatar
VK56 Inside
For suspension only I would just add the Sway Bar Bushings. I would stick with OEM too.
Old Feb 17, 2006 | 05:51 PM
MDeezy's Avatar
Originally Posted by DragonMaxima
Mdeezy,
I purchase the quote above from best suspension suspension (ebay) for $210 shipped.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
- strut mount
- strut boot
Dave
I have D2 coilovers so the strut mount, boot, etc arent needed.
THe engine support will get done at a later time when the engine is out of the car. Thanks thought.
Thanks, I thought I there was another one for the sway bars. So there is sway bar links and sway bar bushing?
Old Feb 17, 2006 | 06:31 PM
Feed's Avatar
I think the sway bar mounts to the subframe, but I can't recall. The bushing would go there, however.
I agree with the OEM comment. If the aftermarket ones are +/- 1mm wrong, plan on getting new ones.
Old Feb 17, 2006 | 06:41 PM
MDeezy's Avatar
Yes, I'm going with OEM, I want to keep (restore really) the factory smooth like ride.
Matt93SE
May 24, 2019 02:58 PM
Roman777NYC
Nov 7, 2015 10:13 PM
95Maxi
35
Sep 2, 2015 10:37 AM
Team STILLEN
Aug 10, 2015 04:29 PM
