ngk iridium?
Originally Posted by NmexMAX
Coppers last 30k... Ir last longer than Pt...
Why did you quote me?
Originally Posted by DaEnigma
The
Originally Posted by acidspit86
how do the iridium spark plugs compare to the platinum?
Originally Posted by Mxrider52
Dont last as long like 30K compared to 60K for platinum
Got my car in '01 after a year decided to change the plugs. I did an OEM swap there were NGK platinums inside. 2 yrs later I read about Iridium and wanted to try them. I went with Denso due to the fact the "electrode is smaller and can carry a better spark." this is coming from Denso. To tell you the truth really can't tell any difference.
Platinum is good, but the only reason they ever made platinum plugs was that they didn't have the technology to make iridium plugs cost-effectively. Iridium is better than platinum in every way, so now that iridium plugs are available, there's really no reason to use platinum IMO.
Now, to clear things up about how long they last...
DENSO Iridiums last ~30k-50k miles because of their super fine electrode tip, but can indeed give you a better spark. NGK Iridiums last ~100k miles.
I should know... I've used both (had Denso Iridiums, now on NGK Iridiums). And I drive my car pretty damn hard, so I notice differences.
Cliff's Notes:
Denso Iridium = Best spark, OK life (30k-50k), high price
NGK Iridium = Second-best spark, longest life (~100k), good price
NGK V-Power = Best spark, shortest life (~15k), cheap as hell
Also keep in mind that a copper plug's performance will degrade steadily over its lifetime, which won't happen with a platinum or iridium plug.
All other plugs (including platinum) are not worth considering IMO.
Cliff's Notes:
Originally Posted by Maximious
Dang it why cant i post a new thread? I'm new here and am looking at a 95 Maxima SE to buy, 124k miles. What should I look out for? Its a 5spd, are the trannys good? Thanks.
Maybe if we don't answer the n00bs when they try to jack threads with questions they could have Googled or researched in other threads in less time than it took to post, they'll go away...
I'm running NGK double Platnums but she came with NGK Iridiums. Too pricey when I needed them($16per) Probably will get them next time though. No manual that I've seen for our car says to use copper(so therefore I will not), just platnums or probably iridiums if they were out when they were printed... my $.02
evonder73
Sep 1, 2015 02:21 PM
maxinout93
Aug 20, 2015 02:17 AM
