obdII scanner code P1130
anybody know what it means. the scanner said something about fuel air meter, and the guy that did it said it was a dealer code. he also checked in the book and it said something about a swirl control valve. i cheked the stickies and couldnt find anything. some help please. thanks.
From: a charming town in Connecticut first settled in the 1600s
P1130:Swirl Control Valve Control Solenoid Valve (Only for California)
This system has a swirl control valve in the intake passage of each cylinder.
While idling and during low engine speed operation,the swirl control valve (SCV) closes. Thus the velocity of the vaporization of the fuel and producing a swirl in the combusion chamber.
Because of this operation, this system tends to improve fuel consumption, and increase the stability in running condions.
Also, except when idling and during low engine speed operation, this system opens the SVC. In this condition, this system tends to increase power by improving intake efficieny via reduction of intake flow resistance, intake flow.
The solenoid valve controls swirl control valve's shut/open condition. This solenoid valve is operated by the ECM.
**Note: I would inspect the vacuum lines connected to the SCV. It is located near the Transmission dip stick, If manual it is under the Intake Resonator. This is the square shape box that is attached to you Mass Air Sensor. If need be replace the whole SCV.
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
