Caliper maintenance? Possible?
Old Feb 27, 2006 | 09:39 AM
texasluva's Avatar
I think my calipers are going bad. I live in arizona so there is no weather wear. I only have 60k on the car. I dont want to go buy new ones, is there a way to service them?
Old Feb 27, 2006 | 10:29 AM
Dubbya's Avatar
VK56 Inside
Yes, but its easier to just buy rebuilt ones.
Old Feb 27, 2006 | 12:25 PM
texasluva's Avatar
cant you lube them?
Old Feb 27, 2006 | 12:41 PM
happyricefob's Avatar
V^___^V
http://www.motorvate.ca/mvp.php/301
hope these helps. there are instruction for brake disassembly. the rears are similar to the front.
Old Feb 27, 2006 | 12:50 PM
Dubbya's Avatar
VK56 Inside
You can relube them, but its a PITA to do. You have to take the caliper off the car, pop out the piston with air, clean, replace seals, regrease, and reassemble. Rebuild kit costs ~$30 to do both. Rebuilt caliper is about $40 for one.
Old Feb 27, 2006 | 01:02 PM
bobjohnson's Avatar
Blazin......
#1. Dub whos that girl in your avatar....?
#2. Where did you find the rebuilt caliper for 40bones... ? man i just did both rears and they were 100 a piece after the core charge.
Old Feb 27, 2006 | 01:32 PM
Dubbya's Avatar
VK56 Inside
I think auto zone charges $90 and some change for 1 caliper. Minus the $45 core charge it comes out to about $40 per caliper.
Old Feb 27, 2006 | 03:29 PM
Mishmosh's Avatar
I believe the rear calipers and almost double what the fronts are. That said, I think getting the rebuilt calipers are way better than trying to rebuild. It took me a set of rotors (warping) to realize my calipers were starting to stick. If you have the money for it, when it comes time for new rotors, I would definitely swap out the calipers--depends on your situation though.
Apr 16, 2020 05:15 AM
TKHanson
Nov 24, 2018 01:39 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
