Brakes, brakes, brakes, and more brakes
Old Mar 1, 2006 | 05:39 PM
kcryan's Avatar
So because i drive my car like an *** my rotors are warped....
a little reading on this subject has led me to the conclusion that cross-drilled is no good becuse it doesnt help with braking that much and it weakins your rotors significantly.
however, how about slotted? is that bad or useless as well?
Also where do you guys reccomend i get rotors? do i only need the front ones most likely?
and what pads do you guys reccomend, and where can i get them, keep in mind this is a 98 I30, no brake upgrades, ABS, and sees very little if any track duty.
Old Mar 1, 2006 | 05:50 PM
kcryan's Avatar
ohh and ill tack this on as well as its an easy answer (i think) what size is our exhaust piping?
Old Mar 1, 2006 | 06:18 PM
MaximaSE96's Avatar
Maxima Owner
do a 300zx brak upgrade t give u more rotor.....2.5" piping
Old Mar 1, 2006 | 06:19 PM
95mtlMAXSE's Avatar
shift_Puff
get power slot rotors and hawk brake pads...no matter what the car is...this is by far the best brake set up. It's stops really well, lasts long and the dust doesn't isn't brown and doesn't stick to the rim. Try them out...worse case scenario get a big brake kit
Old Mar 1, 2006 | 09:20 PM
nfo184's Avatar
i agree with 95mtlMASE ....I bought POWER SLOT rotors.....60 bucks cheaper on ebay then anywhere....and got some semi metalic or carbon brake pads to stop brake dust....fell in love with them.....looks great...just go very easy on them for the first 100 or 200 miles...they need time to break in ....think about buying a brand new motor...u dont just redline it and rev it till its red hot...u gotta brake it in softly....dont pull any speedracer tricks till after....or else u could damage them
Old Mar 2, 2006 | 03:29 AM
kcryan's Avatar
Ebay is reliable enough for this? also should i get all 4 or just the front 2?
Old Mar 2, 2006 | 03:37 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Brembo blanks, HPS pads/.
Old Mar 2, 2006 | 03:51 AM
Iron Scimitar's Avatar
Tha Snatcher
AMEN............
Old Mar 2, 2006 | 11:48 AM
kcryan's Avatar
damn now i got a choice to make haha
and bump on my last Q
Old Mar 2, 2006 | 12:54 PM
Akumachan's Avatar
I never narc'd on nobody.
Ebay is fine as long as you go with a good brand name.
Old Mar 2, 2006 | 01:04 PM
North's Avatar
3rd the brembo blank + Hawks
Old Mar 2, 2006 | 01:10 PM
kcryan's Avatar
how u like the fuzions?
Old Mar 2, 2006 | 01:32 PM
Akumachan's Avatar
They sure dont last long, but they grip really well. I went through a pair of em in about 7,500 miles.
Old Mar 2, 2006 | 02:05 PM
kcryan's Avatar
Damn
keep the suggestions + ideas comin guys
Old Mar 2, 2006 | 03:49 PM
Nealoc187's Avatar
SLOW
Don't bother with slotted rotors unless you are going to be at the track with them. Waste of money and wears your pads down faster, doesn't offer any better stopping under any conditions you will ever see on the street. Any ol' blank rotor and Hawk HPS pads and you are good to go.
Old Mar 2, 2006 | 04:07 PM
kcryan's Avatar
THANK YOU! thats the answer i was looking for...
Old Mar 2, 2006 | 05:18 PM
S Cranaw's Avatar
I agree. I'd go with flats. I had x-drilled and slotted. All I got was a ton of vibrations under normal driving conditions. Got old really fast. I have flats right now. Much more comfortable, but I did notice slight.... I mean a slight loss in stopping power.
-Steve
Old Mar 2, 2006 | 05:33 PM
vsamoylov
did you need a spacer? the part of the rotor that isnt used looks out of place.
i had no problems with drilled and slotted cobra rotors. just get a good brand.
Old Mar 2, 2006 | 07:09 PM
MaximaSE96's Avatar
Maxima Owner
yea he used spacers
Old Mar 3, 2006 | 08:48 AM
Tim96I30t's Avatar
-Steve
I don't know what noise and vibrations people are talking about. I have had CDS rotors, cheap ones $120 for 4, and they are great. No noise, vibrations, and have lasted about two years in the NE with no warping or cracking. Much better than the oem pads in terms of cooling and brake fade. I have had axxis ultimates on them and they are the best setup I have had on my I30 so far. Braking is far superior than the oem setup in every way possible.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
