l.e.d. question please help me out b4 i bid
Old Mar 2, 2006 | 07:48 PM
97maxxx's Avatar
http://cgi.ebay.com/50X-New-5mm-Supe...QQcmdZViewItem i am looking at some leds to do a swap for my window switches/climate control etc so i figured i would go with about 50 and i would also get the 50 resistors to go with it -so my question is in this auction there are 50 legs and it comes with 50 resistors -are they the right size resistors to do this b/c last time i ordered this stuff i installed them and blew the leds b/c i think i got he wrong resistors-so please let me know if they are the right ones and also if these leds will be good/bright enough thanks
Old Mar 2, 2006 | 08:00 PM
tikiboom's Avatar
I need an intervention
the window switch circuit boards already have resistors built into them. I just replaced the LED's w/out resistors. A month later and they havent blown yet
Old Mar 2, 2006 | 08:03 PM
97maxxx's Avatar
awesome well i never tried to do the switches yet -i only did the climate and those blew-but would these work for that ? and what size did you use for the switches
Old Mar 2, 2006 | 10:16 PM
97maxxx's Avatar
i think i have decided on 5mm but what mcd is the best -what do youll think?
Old Mar 2, 2006 | 11:01 PM
Cdg2125's Avatar
I've been told that the 5000 mcd is plenty. That's what I'm going with. 3mm 5000mcd Super Bright Red. I'm psyched...just gotta make sure I know what I'm doing before I spend the money haha.
Old Mar 2, 2006 | 11:47 PM
siballiance's Avatar
if u want for tail lights.
you need :
Led's 5mm RED
(radioShack) vavoboard, or some **** like that
soldering thingy.
if u want i want resistors, its up to you.
heat gun to open your taillight. (home Depot)
and i tell you. its not hard is annoying.
u'll spend most of the time soldering.
if you need any help Pm me.
Old Mar 3, 2006 | 04:47 AM
mendon99's Avatar
tastey wheat
and they won't, you only need resistors on the climate control, and if you're adding them somewwhere else randomly by themselves (guages, vents, handles etc.)
basically where ever the write up calls for.
Old Mar 3, 2006 | 06:04 AM
tikiboom's Avatar
A climate control LED blew on me the other day and I think its because while the car is running, voltage jumps from 12V-15V+(?) and the resistors i got are to match a 12v current. Im thinking of using a volatge regulator and running all my LEDS off that. Now if i only had time
Old Mar 3, 2006 | 06:59 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
10,000 MCD is very powerful for an LED, that's as high as I have seen blue ones go (at least 5mm ones). You will need about a 500-ohm resistor for the rear and passenger side switches, you can easily get them at radio shack, which I would recommend, as they are made of much more durable metal.
Old Mar 3, 2006 | 07:16 AM
97maxxx's Avatar
thanks metal maxima -i really wanted to ask you since you have so much experience with leds.- i am looking at 2 different auctions so what do you think i should go with 5mm 10,000mcd or something lower at about 5,000 mcd? what size leds do you all have in your cars now?
Old Mar 3, 2006 | 09:53 AM
All 5mm for now. I'll be using 130,000MCD when I redo my maplights. Higher MCD rating FTW. You'll be happier in the long run.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
