Rear wheel drive 4th gen Maxima
Old Mar 9, 2006 | 09:11 AM
95mtlMAXSE's Avatar
shift_Puff
Ok, I was discussing in a thread of possibilities to make a maxima rear wheel drive. I think it's possible and want you peoples opinion on this. If the rear suspension is removed entirely and a differential would be in it's place, it could some how work, no?? Swap everything from a 300 zxTT, get a custom drive shaft and it should fit. Apart from ground clearence issues with the driveshaft from tranny to diffy, it should work right?? Let me know, cause maybe I'll try it out and let you guys know. Ideas are welcome
Old Mar 9, 2006 | 09:21 AM
Jeff92se's Avatar
I'm needing a caw
Yup. Even better is Stillen developed a kit for this. Why? Because you aren't the 1st guy to think of this. Stillen's kit p/n is MaxR-3.0. Their number is Phone: 866-250-5542
Old Mar 9, 2006 | 09:22 AM
95SEfreak's Avatar
well that might be a lot of cash....but.... that sounds like it would work might be a very tight squeeze but i must say a rear wheel drive max would be awesome i say why not go for it. If it does not work jsut sell part and put stock parts back on and atleast you tried
Old Mar 9, 2006 | 09:25 AM
95SEfreak's Avatar
oh a kit how much is it?
Old Mar 9, 2006 | 09:26 AM
95mtlMAXSE's Avatar
shift_Puff
ok, i'll call now and let u guys know
Old Mar 9, 2006 | 09:27 AM
aih98max's Avatar
scoobystoned...
that would be so kick ***. id go 4 it if i had the time and money, but id have to go back to driving my 85 nissan pickup while i was doing that to my max.
SEmy2K2go's Avatar
Go BUCKS!!!
See if they have an updated kit for the 5.5th gens too.
Old Mar 9, 2006 | 09:29 AM
Scooobay's Avatar
I always wondered ...what would be the advantages of a rwd maxima over a fwd maxima...lets say if we kept everything stock....any hp diffrence...traction difference???
Rick James's Avatar
Old Mar 9, 2006 | 09:33 AM
l3ftonm3's Avatar
thank you jeff92se for replying to this thread and causing posts thereafter and making me laugh. down the line they fall.
Old Mar 9, 2006 | 09:37 AM
95mtlMAXSE's Avatar
shift_Puff
ok, i called and they're like, "NO, we never had that" so I guess that part number isn't correct. I think it would have to be a frankenstein design. Maybe a ruinned 300zx(accidented) and all the necessary parts are ok, maybe we can make it fit. A rear wheel drive Max would be tooo sick. You'll see me at drift mania with a huge MAXIMA.ORG decal on my rear windsheild and a big smiley face next to it. It would drive the way it's meant to feel. I love rear wheel drive cars and always wished the max was.
For differences between a front wheel and a rear wheel drive is like night and day. The car would feel more balanced. Maybe a slight loss in power due to the differential, but with 2 turbos or even just one, who the hell cares. You have a forced induction, rear wheel drive Maxima. Maybe if it works, they can make a kit for it. The 4th and 5th gen max's should be the same underneath, so it would probably work on both if it works on one. I promise if this would work out, you guys will hear about it.
Old Mar 9, 2006 | 09:42 AM
DJMaxGLE's Avatar
Ugh, I'm probably the last person someone would ask about cars and even I know this is a stupid idea. Quit wasting bandwidth on this mindless crap and buy a new car if you want RWD so badly.
Old Mar 9, 2006 | 09:51 AM
mzmtg's Avatar
Minister of Silly Walks
http://forums.maxima.org/showthread.php?t=368829
MorpheusZero's Avatar
Hahah, that was aweomse Jeff.
Think about it though. The Maxima is built on a FWD platform using a rear beam suspension, you'd definitely need to gut the rear suspension and put some independent stuff back there (which would be REALLY nice). If you're lucky the new suspension and the differential in the back of the car would weigh the rear tires down a bit (isn't the stock weight distrib. like 65/35?) so the car won't always be squirrelly. The 4th gen actually has a "hump" in the passeger compartment unlike quite a few FWD cars, so you might be able to relocate some stuff and run the driveshaft through there..... although the hump was there for a reason, so you probably can't. And I know this has been speculated 1500x already, but I'm just thinking out loud I guess.
Anyway, if you wanna prove everyone wrong, do it, slap two VG30DETTs together and shoehorn in a W12 quad turbo as well. That'll show 'em, you'll be a god. But you won't get much but sarcasm in here until after the fact.
joaquink's Avatar
żHablas Espańol?
WTF?!? It's been done.
Old Mar 9, 2006 | 09:52 AM
Progress's Avatar
It's business time.
While you're at it, you should mount a perpendicular drive train from the bottom of the car to the top and turn it into one of those cool R/C cars that flips and stuff. Of course that would make it really heavy but with a turbo for every wheel it should work. Better yet, cut holes in the floor for Flintstones mode. FTW!
Old Mar 9, 2006 | 09:55 AM
MaximaSE96's Avatar
Maxima Owner
haaaaaaaaaaaaaaaaaaaa...Jeff sooo funny......again like i sai with the vq30det thread with money anythign is possible
Old Mar 9, 2006 | 10:23 AM
d00df00d's Avatar
Old enuf to pick his own gears
Possible? Of course. Intelligent? No.
1. No good engine and transmission will fit longitudinally without total destruction of the firewall
2. There is no room to run both a driveshaft AND exhaust in the central tunnel, no room to cram good mufflers into the engine bay for side exhausts, and no convenient way to route the exhausts along/around the undercarriage without destroying ground clearance.
3. There is no room to fit a good suspension setup in the rear.... Either you keep the beam and end up with a TON of unsprung weight in the rear, or you improvise the most stone-aged piece of crap the automotive world has seen in a long time, and either way the handling and dynamics will SUCK
Of course, gutting the interior and tearing up the chassis would solve everything. But then you'd have spent ungodly amounts of time and money just to end up with a 4-door, 2-seat car that is dynamically mediocre. And then you'd have to kick your own **** out of respect.
So don't do it.
BTW, will someone finally sticky this isht? Maybe put it in the FAQ or something?
Old Mar 9, 2006 | 10:28 AM
95SEfreak's Avatar
if you love oyur max and want to do it then do it dont let people who think its a stupid idea stop you
REMEMBER: you only have one life live it to its fullest
JClaw's Avatar
That was hilarious.
You want a RWD VQ, stuff it into a 240sx and call it a day. It's much lighter, already has a nigh 50/50 weight distribution and IRS.
Old Mar 9, 2006 | 10:32 AM
D-Bo's Avatar
Droppin logs
You should call the guys over at Mosler (561) 842-2492 and they can hook you up with a dual engine setup. An additional engine in the rear driving the rear wheels would be M@dd SiCk YOO!! Then you could drift in two different directions at the same time. Oh the cookies!
Old Mar 9, 2006 | 10:35 AM
95mtlMAXSE's Avatar
shift_Puff
First things first, it wouldn't cost much. You get a complete parts car and used whatever is needed from it and all other brackets and mounting hardware can be made and welded together. Also i wouldn't just buy a new car if I really like the car itself, like the feel of a rear wheel drive and it's possibilities. So yeah it would be worth it. Maybe not for all of you, but i'm not alone on it that's for sure
Old Mar 9, 2006 | 10:36 AM
Supermax95's Avatar
rofl, for a 38 year old guy you still know how to joke around and prank people...lol
Old Mar 9, 2006 | 10:42 AM
Supermax95's Avatar
NEVER us maxima owners like to find reasons to flame people
Old Mar 9, 2006 | 10:43 AM
97SEdriver's Avatar
this place is dead
Originally Posted by Nancy Kerrigan
WWWHHYYYYYYY?????
that wasn't right.
but Jay Leno did do the same thing to a Torino, but he DID spend a hunk of change on that swap (but still less than a Bentley, which is what he was aiming to beat)
Old Mar 9, 2006 | 10:45 AM
95mtlMAXSE's Avatar
shift_Puff
i thought of it already d00df00d...i have a car that's worth trying it on...If it never works, f*** it. I figured the space in the rear would have been enough to make it work
Old Mar 9, 2006 | 10:48 AM
2 Da Max's Avatar
its been done, my friend has an old magazine with a yellow max that was rwd. i think me or him had posted pix of the mag a while back
Progress's Avatar
It's business time.
How much money and time are you willing to spend on the project?
Old Mar 9, 2006 | 10:50 AM
95mtlMAXSE's Avatar
shift_Puff
Well 30 min ago about $2000 grand, now, nothing...i'll stick to my original plan. Never thought i'd get chewed up and spit out like that
Old Mar 9, 2006 | 10:51 AM
Fr33way™'s Avatar
Wild for Width
You can get most of the stuff at ACE Hardware, don't even deal with Stillen.
Old Mar 9, 2006 | 10:53 AM
Fr33way™'s Avatar
Wild for Width
BTW enough time and money can make anything happen.
Old Mar 9, 2006 | 11:02 AM
95mtlMAXSE's Avatar
shift_Puff
yeah, i have little patience...i guess it was a pretty dumb idea, but i know it is possible if you won the lottery(to make it perfect). whatever enough of this rear wheel crap
Old Mar 9, 2006 | 11:03 AM
Progress's Avatar
It's business time.
That's the talk I like to hear; quitting!
Old Mar 9, 2006 | 11:06 AM
95mtlMAXSE's Avatar
shift_Puff
a little harsh, no??
Old Mar 9, 2006 | 11:07 AM
Progress's Avatar
It's business time.
If you say so.
Old Mar 9, 2006 | 11:08 AM
Jeff92se's Avatar
I'm needing a caw
World Peace?
Old Mar 9, 2006 | 11:09 AM
Fr33way™'s Avatar
Wild for Width
That's not going to work for any mods that come from your own creativity, large or small.
Old Mar 9, 2006 | 11:11 AM
Fr33way™'s Avatar
Wild for Width
World Peace?
a LOT of time and a LOT of money? (a LOT of love )
Old Mar 9, 2006 | 11:12 AM
95mtlMAXSE's Avatar
shift_Puff
yeah i do...no reason to b
Old Mar 9, 2006 | 11:14 AM
Progress's Avatar
It's business time.
Would you like a ?
