car inspection
Old Mar 9, 2006 | 08:52 PM
alleydawg6's Avatar
Livin dreams thru his Maxima
car inspection
ok ... I need to have my max inspected ... the inspection sticker is from 2004 ... anyone know of a cheap place ? I have the check engine light for KS sensor and EGR sensor, also the Megan full catback system ... thanx in advance
Old Mar 10, 2006 | 03:50 AM
njmaxseltd's Avatar
The exhaust might not be a problem if you go to a private garage for the inspection, but you've got to fix the EGR system and make sure the KS code goes away as well or you cannot pass NJ inspection.
Old Mar 10, 2006 | 06:31 AM
Juicey's Avatar
This ORG has saved me $$$$$$$$
Get a KS from eBay for like $70. Generally the cheapest inspection I've seen cost $10. What does it usually cost $12-$15? Pretty cheap, perhaps you're asking if there is a place you can take it that will overlook the KS and EGR....
Old Mar 10, 2006 | 06:38 AM
loverholic's Avatar
iAMIXAM!
i thought inspection was $35 no mater where you go..........
Old Mar 10, 2006 | 06:45 AM
bigdog97max's Avatar
you should probably ask this in the regional forums. inspections are different everywhere.
edit: didn't see you're from jersey, you will definately fail if you have any codes (and resetting the ecu doesn't work), they didn't hook a sniffer up to my car, just hooked some thing up to the ecu and that was all. i would say either fix the codes (not really that hard and better for your car) or try to find a shady place that'll pass you for a fee.
Lakersallday24
Jun 16, 2019 01:35 AM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
doobadoo
Aug 15, 2015 06:43 PM
yat70458
Aug 3, 2015 01:16 PM
