Rim Question
Old Mar 10, 2006 | 05:01 PM
Rit's Avatar
Rit
Rim Question
When you replace the 98 5-star SE wheels, with 2000+ Nissan Rims, do the '98 lug nuts still fit. FOr some reason, I though they used a different type. Not sure where I got that idea.
Old Mar 10, 2006 | 05:07 PM
99grnmaxgxe's Avatar
I'm not exactly sure but I'm guessing yes.
MDeezy's Avatar
they fit because the bolt pattern is the same.
Old Mar 10, 2006 | 05:09 PM
DominanceX's Avatar
i believe they should..i have a 2003 rim and use it as a spare since i only have one....i have a 95...it should fit...unless there something idk bout..
Old Mar 10, 2006 | 05:51 PM
Rit's Avatar
Rit
Lugs
I'm not talking bolt pattern. I really am referring to a different type of lug nut. Do they all use the standard chrome acorn nut?
Old Mar 10, 2006 | 05:54 PM
MDeezy's Avatar
same lugs also . . .
Old Mar 10, 2006 | 06:26 PM
pmohr's Avatar
No more Maximas...
As MDeezy said, you're only replacing the rims, not the studs. The lugnuts still fit on as if you were using the stock rims. Same with any other aftermarket rim, assuming it's the same bolt pattern, you just put on the rim and the lugnuts still work.
I think 95-06 use the same studs, M12x1.25 (oddly enough, that's the same spec that our oil pan drain plugs are...random knowledge). I know 2nd gens use a different size, but not sure about 5th/6th being the same.
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
Serotta33
Sep 17, 2015 12:14 PM
0m3nc0w
Sep 11, 2015 05:21 PM
adamgalazka
Sep 8, 2015 01:27 PM
