Changed Front O2 Sensors -- Codes Returned??
Old Mar 11, 2006 | 06:02 AM
MikeinMadison's Avatar
Hi all
'96 SE
Last week I changed my front 02 sensors with the appropriate Bosch replacements. I also changed my knock sensor. I reset the ECU and both O2 sensor codes returned. Any ideas? Thanks for any help!
Old Mar 11, 2006 | 10:26 AM
99grnmaxgxe's Avatar
Are you sure you replaced the right sensors?
Old Mar 11, 2006 | 10:57 AM
Jokester66's Avatar
I also have my check engine light on for EGR and front Oxygen Sensor on the left cylinder bank. i was wondering how much this part would cost? and any other suggestions to what might be wrong?
Old Mar 11, 2006 | 11:28 AM
Oh yeah -- I'm sure I replaced the right sensors. Hard to screw that up. 3-wire O2 sensors -- two whites, one black, no polarity, so doesn't matter how they're wired. Ideas?
Old Mar 11, 2006 | 11:40 AM
clive's Avatar
100% chingon
You HAVE changed the air filter recently?
Old Mar 11, 2006 | 02:13 PM
My suggestion is to just drive for about 2 weeks and see if the code goes away. It has done this before to me and also others.
Old Mar 11, 2006 | 03:21 PM
I changed the air filter a couple of months ago. I'll check it. So sometimes the codes come back and go away? I can understand why they might not go away immediately, but why would the ECU send a code after reset like this? Unless there's still a problem?
Old Mar 11, 2006 | 03:51 PM
zazon's Avatar
had the same problem, damn fuse was blown! i would check the fuse, sounds just like the prob i had. i forget the exact location, its the right bank of the in-car fuse panel... somewhere around the middle. if that helps
Old Mar 13, 2006 | 01:33 PM
Thanks zazon, I'll check that tonight...
Old Mar 13, 2006 | 07:47 PM
FishyMan's Avatar
my code left me??! for the 0707
but im still gonna change it, might as well anyway.. also what fuse did u guys mean/
kjlouis
Nov 24, 2018 06:09 AM
homeyclaus
Sep 3, 2015 06:15 PM
Maxboy23
Aug 21, 2015 11:02 AM
wingnut2006
Aug 15, 2015 04:16 PM
RealityCheck
Aug 5, 2015 06:18 AM
