Found an extra pound of weight reduction
Old Mar 13, 2006 | 02:02 AM
Maxima_Joe's Avatar
4th Gen Parts King
Well i found an extra pound of weight reduction tonight. It is a metal plate inside the glove box. If you don't want to remove the entire glove box then this is for you.I'm sure this is there for added accident protection.
Old Mar 13, 2006 | 07:08 AM
Dubbya's Avatar
VK56 Inside
Nice find. Mine is coming out tonight.
Old Mar 13, 2006 | 07:18 AM
99grnmaxgxe's Avatar
Pretty cool, probably will help by 0.000000000000000001 seconds in the 1/4.
Old Mar 13, 2006 | 08:14 AM
Dubbya's Avatar
VK56 Inside
Weight reduciton isnt about how much one peice will shave off. Its about the combined weight of several peices. :
Old Mar 13, 2006 | 08:49 AM
devilz05's Avatar
Shift_3.0
How about going the old fashioned way and trying the Atkins diet...
Old Mar 13, 2006 | 10:38 AM
JClaw's Avatar
At the weight of the max, it only takes about 75 pounds to shave 1 tenth off your time. The lighter the car, the bigger difference it makes. Shaving 50 lbs off a 2000 lbs car is like shaving 100 lbs off a 4000 lbs car. At 3000 it's about 75 pounds.
Old Mar 13, 2006 | 01:19 PM
bobjohnson's Avatar
Blazin......
Just wondering~... But how big are you guys?
Has anyone thought about putting themselves on a weight reduction...?
Im 165lbs, When i have my cousin who is 245lbs in the car with me... its alot slower but i can't see 1lb here, 3lbs there adding up to a significant 150lb loss.
Old Mar 13, 2006 | 01:32 PM
Mxrider52's Avatar
I support for what?
Just adding coilovers is 30-40 lbs off right there then add aftermarket wheels etc it will add up
Is the glovebox still functional?
Old Mar 13, 2006 | 01:45 PM
Maxima_Joe's Avatar
4th Gen Parts King
I never thought about this. But they weight may be there so they glove box drops down when it's unlatched. So it may not stay open by it's self. You may have to undo the string that helps it close.
Old Mar 13, 2006 | 04:00 PM
86maxima96's Avatar
I Broke OT
again, you have to understand that it does add up. it may not seem like much for each piece, but like you said, even with your big friend, you could tell a difference. so when it all adds up, it is noticeable.
Old Mar 13, 2006 | 06:05 PM
Pieps's Avatar
I did this today, and my thought is that every little bit helps. It doesn't restrict the functionality of it, and it saves a little over a pound. It is a win-win situation
Old Mar 13, 2006 | 06:47 PM
tikiboom's Avatar
I need an intervention
And then drop a sub or 2 in the trunk. Goodbye weight reduction
Old Mar 14, 2006 | 03:26 AM
Jime's Avatar
Coilovers saved me 6 lbs ea in the front the rear is less because the springs are much smaller but I haven't weighed them yet. My estimate is less than 20 lbs total.
Old Mar 14, 2006 | 04:35 AM
BEJAY1's Avatar
Conecarver
Every little bit adds up - I found lots of little 1lb pieces last weekend
Old Mar 14, 2006 | 06:53 AM
aznsap's Avatar
good find fanatic. has anyone put their glovebox back to see if it will drop down normally when unlatched?
and do coilovers save significant amounts of weight over an aftermarket suspension setup? i feel like my tein s-techs and tokico illuminas should be lighter than the oem suspension when i swapped it out.
i'm 5'9", 140 lbs. i don't really think i can afford to lose any weight myself.
Old Mar 14, 2006 | 11:50 AM
Mxrider52's Avatar
I support for what?
When I installed my D2s I weighed the front strut OEM to the D2 coilover and got a 14 lb difference each so times that by 2 that 28 lb loss but I didnt weigh the rears
Old Mar 14, 2006 | 05:39 PM
geo1317's Avatar
Your passenger wont be too happy about their knee going through the glove box. But then again if you want to save wait you shouldn’t have passengers anyway.
Old Mar 14, 2006 | 11:15 PM
nathan91tt300zx's Avatar
How fast do you run at the strip with all of the weight loss?
-Nate
Old Mar 14, 2006 | 11:22 PM
Maxima_Joe's Avatar
4th Gen Parts King
-Nate
http://forums.maxima.org/showthread.php?t=433426
That was the last race last year. This years season will start shortly. I will be at least 400 pounds lighter and be on drag slicks.
Old Mar 15, 2006 | 07:27 AM
ptatohed's Avatar
Licensed to Spell
So what was the answer about the glove box still operating properly? Does it still fall open slowly on its own when the handle is unlatched? Does it stay open on its own? Thanks. Good find.
Old Mar 15, 2006 | 07:33 AM
tikiboom's Avatar
you want weight reduction? put one piece cefiros in. Christ what a nightmare
Old Mar 15, 2006 | 07:55 PM
Maxima_Joe's Avatar
4th Gen Parts King
post #11 says he did it with no problems. I won't bother doing it since i don't use a glove box for my drag car.
Old Mar 15, 2006 | 08:46 PM
sterlingmaxima's Avatar
do you got a llink for the weight reductions you did?
Old Mar 15, 2006 | 08:55 PM
Maxima_Joe's Avatar
4th Gen Parts King
http://forums.maxima.org/showthread....ghlight=weight
Old Mar 16, 2006 | 06:51 AM
f550maranello2's Avatar
you know what works better than taking the weight off the car.. taking weight of the driver... go to the gym.... lol and for added weight reduction take a dump before you drive
Old Mar 16, 2006 | 10:48 AM
DandyMax's Avatar
3.5 in the works
That glove box piece is old news.. (unless you are just discovering it now)
Old Mar 16, 2006 | 10:51 AM
Jime's Avatar
Mine is now non operational and even lighter. Hey did you get my pm reply?
I remember reading about the plate behind the glove box but I didn't know where it was until now.
Old Mar 16, 2006 | 10:54 AM
Dubbya's Avatar
VK56 Inside
Are you trying to say I need to lose weight? I do go to the gym, but its to gain weight.
tavarish's Avatar
fwd gone rwd cr00
i just removed my cruise control system, thats good for another pound, and it adds mounting locations in case you wanna mount something to the firewall.
Old Mar 16, 2006 | 11:07 AM
ok so ur gaining weight but taking weight off the car....
dude seriously... think about what u just said....
Old Mar 16, 2006 | 11:14 AM
Fr33way™'s Avatar
Wild for Width
I mean he is trying to gain muscle, he is not just eating full pizzas all day....
Old Mar 16, 2006 | 11:35 AM
ptatohed's Avatar
Licensed to Spell
There is no contradiction in adding weight to your car (or yourself) but also wanting to do all the weight reduction you can. For instance, I knew by adding my double din Kenwood 8017 DVD/Nav. along with a separate navagation unit and a separate CD changer would add weight to the car - but I really wanted Nav. and a changer. Period. So does that mean that I should not remove the 4 tow hooks from my car to shave 4lb? I shouldn't remove the metal plate under my steering column to shave 1+ lb? Just because you might be adding weight from a certain mod that's important to you (like say a ground effects kit) doesn't mean you shouldn't reduce all the weight you can in other areas.
Old Mar 16, 2006 | 11:54 AM
it doesnt matter.... if you subtracting weight form the car and you gain muscle (weight)..... you arent helping to loose weight from the car ur keeping it the same....
so yea take 20lbs from the car and gain 20 lbs of muscle....lol
Old Mar 16, 2006 | 12:01 PM
ptatohed's Avatar
Licensed to Spell
:o)
Yes it does matter. In your example: take 20 lb from the car, add 20 lb to the driver. Net gain zero, right? But what's the alternative? Do no car weight reduction but still add 20 lb to the driver? That would be a 20 lb gain.
Like I said, even if you are going to add weight to your car, it is still beneficial to reduce it whereever you can.
I don't see how you don't see that.
Old Mar 16, 2006 | 02:14 PM
Maxima_Joe's Avatar
4th Gen Parts King
I knew about the other bar and brackets behind the glove box but never heard of this plate inside the glove box.
Old Mar 16, 2006 | 02:25 PM
Dubbya's Avatar
VK56 Inside
Im not even going to argue this point anymore. It has gone way past the point of retarded.
Old Mar 16, 2006 | 06:04 PM
Pieps's Avatar
Dubbya...True that
Old Mar 16, 2006 | 09:13 PM
MorpheusZero's Avatar
Hahahahaha, okay.... let's think this through... yes, gaining 20lbs and shaving it off the car will net you nothing performance wise. But the other alternatives are: a) gain no weight and shave no weight or b)gain weight and shave no weight. One of these gives you the best of both worlds.. although 20lbs won't exactly make or break a race, that doesn't mean that what you're doing is stupid.
Old Mar 17, 2006 | 04:20 PM
Aaron92SE's Avatar
NWP Engineering.com
What happens if you already weigh 130 lbs? And have done exactly 550lbs of weight reduction to your car?
Oh yeah, I ran the 14.3 with 410 pounds of weight reduction done. I have lots of other stuff up my sleeve in order to easily get 13s within the next couple weeks.
Old Mar 17, 2006 | 06:49 PM
ptatohed's Avatar
Licensed to Spell
Does anyone have a link to that thread an .org member put together a few years ago with a list of weight reduction? He had a Stage I, II, III. I forget his name and I forgot to save the link. Thanks.
