need help on removing black outer or inner bracket for stereo install
Old Apr 3, 2006 | 09:48 PM
Ceasars Chariot's Avatar
Old Maxima Legend
how do i get this silver bracket out or remove the outer black plastic to get to it, not really doing a stereo install but need to pull it out to fill it with a black trim plastic
Old Apr 3, 2006 | 09:50 PM
VIP Maxima
http://www.carstereoremoval.com/htm/...xima95_99P.htm
i think that write up tells you how to remove the whole dash. i dont remember but i used it like 3 years ago.
edit: back then it was free i guess now u have to pay to view instructions.
Old Apr 3, 2006 | 09:53 PM
97maxxx's Avatar
okay i see that you have the shifter area off -now make sure that pop out piece is open which it is in that pic -it comes right out its only held on by clips -now you can see the 2 bolts on the bottom -next take off the top vent part-that also is just held on by clips-then you can see those 2 bolts -now the whole thing will come off -the black piece which you want the framwe and the climate control -from there just unscrew the front -its so easy -i hope that helps a lil
Old Apr 3, 2006 | 09:57 PM
Old Maxima Legend
top vents, not in photo right, you talking about where the a/c blows out air in those vents
Old Apr 3, 2006 | 10:03 PM
97maxxx's Avatar
yup take a flathead and put it inbetween the vents and the climate control and lift -its comes right out and then clips out on the top also -no screws at all on that part -then you can access the 2 screws that need 2 come out on top 2 more on the bottom and that whole assembly comes out
Old Apr 3, 2006 | 10:13 PM
Old Maxima Legend
vents and climate control look like all one piece ? sure for a 97 ?
Old Apr 3, 2006 | 10:25 PM
97maxxx's Avatar
okay this is all i got lol
the part that is all green is one piece-that is what you are taking off first -to take that off pry where i have the red circle -when you pry there the whole green highlighted piece will come off -where the blue circles are thats where the 4 bolts are that you need to take off to take the whole frame off-those bolts you can only get to after you take the vent piece off and that lil pocket piece on the bottom -i hope that clarifies everything
Old Apr 3, 2006 | 11:17 PM
DR-Max's Avatar
Just like 97maxxx said, pry with a flat head along those areas in the pic above ^^^. Do it carefully, you will start to hear a "cracking" lack of a better word. Don't worry its just the spring clips that are disengaging. If you haven't taken the dash apart, it will be very tough to pry apart but it will come off. I've taken mine too many times so its a lot easier for me to take everything apart. Once you have those off, it will reveal two screws that hold the top part of the entire center piece. The other two screws will be down below.
Old Apr 3, 2006 | 11:20 PM
gen4maxima536's Avatar
theres a screw on the left side of the ash tray that you can get to one the shifter trim comes off, then pull the ash tray out (there are two clips on the right side of it), mine took a fair amount of force to pull out
Old Apr 3, 2006 | 11:53 PM
Old Maxima Legend
dude that photo is exactly right, i kept looking and then went down a level between clock and temp thing and there it was, got it all out did the fix i need and im good !! man i love the org !! mission accomplished !!
thanks
Old Apr 4, 2006 | 12:01 AM
DR-Max's Avatar
Awesome! The power of the org reaches all the way beyond down under.
Old Apr 4, 2006 | 06:58 AM
97maxxx's Avatar
no problem ceaser
Matt93SE
May 24, 2019 02:58 PM
schmellyfart
Sep 25, 2015 04:47 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
