Brake Hardware Kit
Old Apr 5, 2006 | 12:37 PM
p00tan6's Avatar
Brake Hardware Kit
When changing the brake pads is it necessary to change or even use the shims? Mines are all rusted and at 20 bucks a set i would rather not change them. Plus most pads these days come with the shim built in for noise purposes. How many of you use or reuse the old hardware kit when changing the pads?
Old Apr 5, 2006 | 02:54 PM
Maxima880's Avatar
Reuse only if they look really good. Brakes really aren't the components that you should cut corners with. Buy the shim kit - sleep better at night.
Old Apr 5, 2006 | 06:18 PM
dgeesaman's Avatar
Maintenance Monster
They are there to prevent brake squeal. I'd buy them from a cheaper source (www.worldpartsexpress.com) and install them when they arrive. I usually re-use mine as they haven't fallen apart yet.
Dave
Old Apr 5, 2006 | 07:34 PM
p00tan6's Avatar
Hey dgeesaman, Im not finding it on that site. Do you have to call it in?
Old Apr 5, 2006 | 08:06 PM
ManualMaxima's Avatar
5th Gen till she dies!
i would replace your pins alot of the time, that is alot of reaosnf or un even brake wear.
Old Apr 6, 2006 | 04:22 AM
katmandoes's Avatar
Definetly get the kit. I look at it this way, had I paid someone to do the job, it would have cost twice the price.
Old Apr 6, 2006 | 06:47 AM
dgeesaman's Avatar
Maintenance Monster
I usually look it up by nissan p/n. You can call it in and ask, or call the local dealer and ask for the part number when they give you their ridiculous price
Dave
Old Apr 6, 2006 | 07:22 AM
p00tan6's Avatar
What do you mean by pins? The 2 caliper pins? I noticed last time i changed it they had a little rust under the boots. Also the inner pad seems to wear out alot faster than the outer pad. Do you have any idea how much the pins would cost? Could i just take them out and clean/regrease them? Is there anything else i should change while im in there?
Old Apr 6, 2006 | 07:58 AM
Buck96's Avatar
try this site, and look up the components you want to purchase...
They have pins, shims, pads what ever you need. Look in the collision catalog under front suspension
http://www.buynissanparts.com/
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
