Caliper slider pins seized - change the pins or new mounting bracket?
Old Apr 6, 2006 | 03:31 PM
lefty
Was doing a quick brake pad change and noticed one of my REAR slider pins is siezied up. Other one moves freely and the rubber boot/seal all looks fine.
The pin is really stuck in there but I think I can bang it out. Can I just replace the slider pin with a new one or do I have to change out the complete caliper mounting bracket?
Any experience would be helpful.
Old Apr 6, 2006 | 04:08 PM
RA030726's Avatar
I'm nutty for Nissans
you can reuse the parts, but you have to remove all the corrosion. i had a stuck pin and the hole was fine because it was protected in the grease. i put the pin in a drill and sanded it clean. then i removed all the old grease and regreased everything. make sure you dont use too much grease. the pin needs to move easily and too much creates a vacuum sucking the pin in. it should slide in and out without sucking back it.
Old Apr 6, 2006 | 04:44 PM
lefty
Thanks buddy.
However, can anything else but corrosion hold a pin in that tight? Using vice grips, I can barely turn the screw but it does move slightly. Is it possible the pin is warped due to un-even pad wear?
Anyway, just for security reasons, dealer sells pins for like $8 so will get a new one jsut to be worry free. But I am curious to see if it actually is corrosion.
k.
Old Apr 6, 2006 | 07:41 PM
BlackMaxdout's Avatar
yeah, corrosion would lock it up in there pretty good. Think about it. You have a hole and a pin, and they hafta fit together in a way that there won't be much slop, so the tolerance between the two are tight. Once some stuff becomes locked in between them, they are essentially mated together. If you can get a new one for $8, I wouldn't worry about destroying the old one while getting it out.
Old Apr 7, 2006 | 04:09 AM
RA030726's Avatar
just inspect the torque member after you remove the pin.
Old Apr 7, 2006 | 05:55 AM
lefty
Agree. Will do as suggested. Last thing I want is to have it sieze up during a road trip and burn out my pads and rotors. That is not cool.
I am going to grab a new Caliper Mounting bracket just to be safe. Can't be that expensive.
Old Apr 7, 2006 | 08:55 PM
lefty
Ended up heating the housing up and the pin released. Looks like the pin got stuck in there with the RUBBER boot corroding and locking it in. It was not RUST.
Old Apr 8, 2006 | 06:50 AM
Frank Fontaine's Avatar
Great post--I actually did two brake jobs on my car without paying attention to the pins. I suspect my back on one side is possibly sticking as the pad seems to be dusting a lot, and only have 30k on the rear. Although the car rolls on a hill in neutral--I guess that doesn't prove anything...
But I did check it carefully a couple weeks ago when I did the fronts for the 2nd time. After 120k on the road, the pins seem to be doing fine up front. I pushed them in and out and they slid well. One I popped out and the grease looked nice and clean. It's ludicrious how much damage can be done when a mfg. uses a cheap supplier of dust boots--a lot of extra parts and labor and premature wear. But, it is an evil car industry we're dealing with! *lol*
Old Apr 8, 2006 | 07:17 AM
Mishmosh's Avatar
Hey thanks. I never got what the sucking phenomenon was about or if it was normal. I appreciate the explanation.
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
-ReLLiK-
Sep 8, 2015 12:02 PM
