Is this legit?
Old Apr 12, 2006 | 08:11 AM
Socrates's Avatar
Is this legit?
So my brother has a 97 maxima that he has taken good care of with 85k miles. Two days ago, totally out of the blue - the car would not move in any gear. It would rev fine though. So it obviously sounds like the transmission went bad.
First off - Is that common for a transmission to suddenly crap out with no warning whatsoever??
Second - How much should a full tranny replacement cost, parts and labor separate?
Old Apr 12, 2006 | 08:20 AM
Tim96I30t's Avatar
I would get a VLSD either from a I30 or newer maxima should be able to get it and have it installed for around $1500. Most of the time a transmission goes with little or no warning signs.
Old Apr 12, 2006 | 08:47 AM
sonicrunch's Avatar
It is if the fluid leaked out.
Old Apr 12, 2006 | 08:59 AM
MaxKlinger's Avatar
5 speed manual or 4 speed automatic?!?!!??
Old Apr 12, 2006 | 09:13 AM
maxinitout's Avatar
its cost me 3,000 for a new tranny and the labor work
Old Apr 12, 2006 | 09:19 AM
MDeezy's Avatar
A tranny for our cars cost between $500-$1k. Labor would be in the area of $300-$500.
I'd say about $1k would be about the price to pay a shop to install a new tranny (with tranny purchased).
If its a Manual, might as well have the clutch replaced at the same time, add ~$250 for a good clutch. (5th gen).
Old Apr 12, 2006 | 10:22 AM
surfman21's Avatar
u got ripped off haha
the one place around here charges 1600 which includes a new tranny, clutch and labor...
Old Apr 12, 2006 | 10:42 AM
clive's Avatar
100% chingon
Strange. No prior symptoms at ALL?
You have checked the fluid level?
If the level is up to the mark and it won't engage gear, there could be any number of reasons, including electrical. If you don't have the knowledge to check it yourself you'll have to take it to someone who does.
Old Apr 13, 2006 | 12:47 PM
MaxKlinger's Avatar
Yeah, I'd definetly check out the linkages. If it's an automatic, the cable may have become disconnected either in the console or on the trans housing. Usually these things give some kind of advanced warning.
If it's an automatic, when was the last time you changed the Trans fluid? What color is it now? Discoloration (brown, gray) and burnt odor probably indicate that the clutches are fried. If the fluid is fresh and pink, I'd doubt it's the transmission itself.
Old Apr 13, 2006 | 01:01 PM
SlackR237's Avatar
Rollin' on 'Caps
Check your fluid. If you have a manual and there's none and your transmission is fine, you're lucky. Just find the leak and fix it/refill the fluid, and you should be good to go.
Alternatively, your tranny may be shot. A day before my 5spd tranny completely bit the dust, I was having lots of trouble getting into each gear. It was just really notchy, then I just couldn't get into gear at all. $1600 later including new clutch, my tranny works just fine.
James92SE
142
Jan 2, 2024 09:23 AM
Lowered_a33
Sep 10, 2015 09:41 PM
Sprint
Nov 13, 2002 09:19 AM
