Cost of auto to 5 speed swap
Old Apr 23, 2006 | 05:25 PM
EdgeVetto's Avatar
How much would it be to have it done. I've read a ton of instructions, and I'm pretty sure that there's no way i could do it myself. So I've been looking around for parts and labor costs (around 2 grand usually). How much should it cost, and is it even worth it. If anyone has a specific place they think I should go to get the switch, throw that in as well.
Old Apr 23, 2006 | 05:40 PM
HallKemar
Since your in Mass., I'd recommend you to come to Ct.,to get a couple of prices around my area..1200 to 1500k at most here.
Old Apr 23, 2006 | 05:43 PM
EdgeVetto's Avatar
thats not bad, definetly worth a drive
Old Apr 23, 2006 | 05:45 PM
VIP Maxima
labor is at least 500. parts is about another 2 grand give or take depending on wut u buy
Old Apr 23, 2006 | 05:49 PM
tavarish's Avatar
fwd gone rwd cr00
I did the whole thing for 900.
Old Apr 23, 2006 | 06:31 PM
EdgeVetto's Avatar
did it yourself for 900, or had it done?
Old Apr 23, 2006 | 06:45 PM
tavarish's Avatar
fwd gone rwd cr00
did it myself, wasnt hard at all.
Old Apr 23, 2006 | 07:11 PM
brad kay
haha that depends on how comfortable you are with ripping the front of your car completely apart and hoping to get it all back together in working order. easy for some, daunting for others.
Old Apr 23, 2006 | 07:19 PM
tavarish's Avatar
fwd gone rwd cr00
it's the first time i've ever done something like that, and it went pretty well. Keep in mind a car is held together by clips and bolts. Just take off the right bolts, and install the parts. Not too hard, you just need a little common sense. if you've ever put together a LEGO set, you could most likely do the swap.
Old Apr 23, 2006 | 07:39 PM
darklegend06's Avatar
tavarish how hard was it to find a 5spd? I've been searching for a 5spd so I can do the swap myself too. Mostly what kind of parts did you use? Also good job on the swap. Hope mine turns out the same way.
Old Apr 23, 2006 | 08:15 PM
tavarish's Avatar
fwd gone rwd cr00
i just bought a 5spd parts car. I just swapped out everything from there.
Old Apr 23, 2006 | 08:37 PM
aznsap's Avatar
there are a lot of members here who have done the swap. i bet you could pay them less than what you would a mechanic and get a good job out of it.
Max139617
Oct 19, 2016 11:34 AM
aminus21
Sep 12, 2015 04:53 PM
I<3 A32's
Sep 10, 2015 11:07 AM
Max139617
Sep 6, 2015 06:02 PM
JoshG
Sep 5, 2015 10:10 PM
