cant use u joint for ks
Old Apr 26, 2006 | 04:12 PM
200kMax's Avatar
no matter what extension i tried. i cant seem to turn the ujoint to get the ks bolt off.
i used 1/4" 12 u joint, and a 3/8" extension, yet i cant seem to turn the bolt.
how the hell do i turn a u-joint bolt at such an awkward angle?
help!!!
worse case, im gonna have to take off the intake manifold. how much work is that gonna be?
Old Apr 26, 2006 | 04:16 PM
jac121479's Avatar
not sure how 5th gens are, but i was able to get the ks off using a u joint. getting i back on my cali spec has yet to happen and i currently have it zip tied to my battery tray.
Old Apr 26, 2006 | 04:27 PM
Maxima880's Avatar
I used a 1/4" U joint with a 1/4" x 12" extension then a 3/8" converter and rachet to get mine off. I remember thinking that I was putting so much pressure on it that the extension was going to twist in two when the bolt suddenly popped loose. Try a 1/4" extension to improve the angle. Did you lube it up first?
Old Apr 26, 2006 | 04:36 PM
200kMax's Avatar
i am using a 1/4" u, w/ a 3/8" converter to a 10" extension.
i think the angle is a bit too high on the u joint in order for me to be able to turn.
am i supposed to be using the ratchet to turn, or just push the extension?
when i turn the ratchet, the socket keeps on slipping off the ks bolt
Old Apr 26, 2006 | 04:41 PM
Maxima880's Avatar
But is your extension 3/8 or 1/4, 1/4 affords the best angle. The socket slipping off is not good. Don't round the shoulders off the bolt. Use a good 6 point socket. Don't push the extension - try to hold it in place while you apply twisting force only.
Old Apr 26, 2006 | 04:49 PM
200kMax's Avatar
the socket is 1/4 and the u joint is 1/4.
i can see that the bolt is not rounded, (yet)....
and yes, i am using a 6 pt socket.
Old Apr 26, 2006 | 04:52 PM
DR-Max's Avatar
Try getting the correct size socket with the u-joint built-in. That should work. Make sure its not a deep socket but I'm sure you knew that.
Old Apr 26, 2006 | 04:59 PM
Maxima880's Avatar
This may be your best choice - Best made before the bolt is damaged. Good Luck
Old Apr 27, 2006 | 05:56 PM
200kMax's Avatar
i finally decided to go one more crack at it w/ the 1/4 ujoint. this time i held the extension upward hitting the v groove on the intake manifold. and woala!!!
finally got it off. took it for a quick test drive after i replaced the ks, and wow, what a difference.
Thanks guys for the advice
Old Apr 28, 2006 | 01:16 PM
projectpete's Avatar
i just did mine, i had the u-joint slip off the bolt many times. i am gong to try and explain what i did. i used a long extension, removed the intake box to give me more room. i then put the u-joint on the bolt, and pushed the extension against the intake manifold to give so the extension wouldnt move back and forth causing the u-joint to slip off the bolt.
do u understand what i mean?
EDIT: i guess i should read all the posts before i make a reply, yeah i did exactly what you did 200kmax
Old Apr 28, 2006 | 03:04 PM
greengrass215's Avatar
you need the serivel socket from snap on if you having a hard time. it fit right in and does not hop, jump off like the one at pep boy. I mean the socket that spin, not the adapter u-joint.
Old Apr 28, 2006 | 03:18 PM
lilaclucymaxima's Avatar
Team Ramrod
I had problems as well... so I payed my little sister $10 to turn the socket for me.
Old Apr 28, 2006 | 06:15 PM
MiL's Avatar
MiL
just keep trying.....i used a 1/2 inch u-joint with an extension and when i turned the socket wrench it worked perfectly......didn't fall off once.....
Old Apr 28, 2006 | 07:19 PM
Apparition's Avatar
Ichiban King
help!!!
well as you can see it was quite painful, and it looked 10 times worse cause of all the bruises but anyways. My little brother wasn't around and I had to use about 6 of those 3-4" extensions (3/8) put together and I still managed it, you have the power its just how far are you willing to go.
James92SE
142
Jan 2, 2024 09:23 AM
user 11122324
42
Jul 18, 2022 03:35 PM
AaronL
Nov 15, 2020 11:52 AM
ivorton23
Sep 26, 2015 09:47 AM
Bonka
Sep 14, 2015 11:18 PM
