high-capacity ACC wire in dash/console?
Old Apr 29, 2006 | 09:11 AM
Speebs's Avatar
I aim to misbehave.
I'm trying to wire up an AC power inverter and need an ACC line capable of supporting it (I don't think the lighter wire is good enough). Does anyone know where there is one?? I have a wire from the passenger power seat, but that is constant 12V.
thx.
Old Apr 29, 2006 | 09:56 AM
JNCoRacer's Avatar
Just the tip.
You could get a fuse-tap from autozone and just plug it in to the interior fuse panel. Thats what I did. Three years and no problems.
Old Apr 29, 2006 | 10:31 AM
RA030726's Avatar
I'm nutty for Nissans
Either use the ignition swtich wires, or get power directly off the battery. You may need to use a relay if you need to make it switched.
Old Apr 29, 2006 | 01:24 PM
Speebs's Avatar
I aim to misbehave.
I needed an ACC or IGN line... I really don't like tapping into factory wiring so I went to Advanced Auto (no Autozones around here) and looked for a fuse-tap, but they only had them for the big fuses. So I soldered a lead wire to a 20A fuse and put it in the empty slot above the power mirror slot. Works like a charm.
Old Apr 29, 2006 | 01:44 PM
whitegold's Avatar
If its drawing alot of power.. run a 8guage line diret from the battery and put a relay to switch it on ACC.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
