part name??????
Old May 1, 2006 | 08:29 PM
nissandrvr's Avatar
part name??????
on the clutch line system there is a small box kinda under the vacuum booster that distributes the fluid coming from the master cylinder....what is it called.....it seems that mine is cloged cause when i bleed my master cylinder it works fine but when i try and bleed the slave cylinder...nothing comes out, so im guessing ill just replace it first and go from there.
Old May 2, 2006 | 06:49 AM
BlackMaxdout's Avatar
if you are talking about the little box that sits on top of the tranny and right next to the slave cylinder...my FSM just says it's an "air bleeder valve". Either that or the "clutch hose connector." The slave cylinder gets bled from the lower bleeder valve, while the master cylinder gets bled from the top bleeder valve (the big one on the driver side strut tower). Theoretically, you can bleed both cylinders at the same time.
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
SpeedCrazie
Sep 16, 2016 03:41 PM
Lowered_a33
Sep 10, 2015 09:41 PM
videomano
Sep 8, 2015 03:28 PM
