fan resistor pics
Old May 3, 2006 | 09:26 AM
200kMax's Avatar
fan resistor pics
does anybody out there have a picture of what a good working fan resistor should look like.
mine is all blown out and i tried to solder all bridgeable links. yet it still doesnt work on 1/2/3.
actually, i heard a humming when i put it on 1, 2, 3. maybe i soldered on a circuit path that i shouldnt have soldered?
if anybody has a pic or a wiring diagram of the resistor board, that would help me a lot in soldering my crappy dead one or.... maybe i should just buy another one.
Old May 3, 2006 | 09:43 AM
Muyrec's Avatar
Here's what mines looks like after i did the fix. A big blob of soldering as i couldn't get it flat enough. I also had to clean the board because it was so dirty you couldn't see the circuits.
Old May 3, 2006 | 10:20 AM
ALSOUSA99MAXIMA's Avatar
OK let the flaming begin wtf is that???????
Old May 3, 2006 | 11:24 AM
Muyrec's Avatar
Blower Resistor.
Old May 3, 2006 | 11:32 AM
Originally Posted by Muyrec
Blower Resistor.
Is that for the heat?? like what blows out the hot air??
Old May 3, 2006 | 11:46 AM
Muyrec's Avatar
it's what basically controls the airflow. That piece breaks and the 4th speed will only work. Hot or cold.
Old May 3, 2006 | 03:12 PM
200kMax's Avatar
just wonderig.. is there supposed to be a connection bridge in the highlighted area. using a circuit tester, i regestered 0 connection here.
i cant tell if there is supposed to be or not.
Old May 3, 2006 | 03:19 PM
UncleMax98's Avatar
It looks like the repair did not do anything. Speed 4 always works because it bypasses the resistor. You need to use a piece of (copper) wire long enough to bridge the gap. Do not use a blob of solder like that. Make sure the wire is thick enough to carry current.
Old May 3, 2006 | 04:05 PM
DR-Max's Avatar
I'd say buy a new resistor, that lil thing shouldn't cost much! Repairing circuit boards isn't worth it at all.
As for ALSOUSA99MAXIMA, buy a chilton or haynes manual so you don't have to ask next time. Just look it up in the book.
Old May 3, 2006 | 04:11 PM
maximaintheface's Avatar
i thiunk they are liek 35-40 bucks form the dealer. i needed one when i first got my car.
Old May 3, 2006 | 04:32 PM
96customax's Avatar
hate to ask but where is it located... im getting a new one (finally) and need to replace it. I looked under dash (passenger side)
and saw wires pluged in right under right foot... is that it?
Old May 3, 2006 | 06:30 PM
200kMax's Avatar
yes, its under the glove box on the passenger side. it is held up by two screws. u dont need to take apart anything to get to it
Miket2006
Mar 1, 2021 03:55 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
