Taking apart CE Red clears
Old May 8, 2006 | 09:56 AM
kenji's Avatar
I was thinking about doing the oven trick on the 95-96 CE Red clears. Anyone know any reason you can't do this?
Old May 8, 2006 | 10:08 AM
D-Bo's Avatar
Droppin logs
It should work Kenji but the question is why? LEDs?
Old May 8, 2006 | 11:03 AM
Swazey's Avatar
make sure the oven isnt too hot, you dont want to melt the plastic
Old May 8, 2006 | 11:15 AM
my97maxi's Avatar
it should work, y would u want to take them off tho??
Old May 8, 2006 | 12:01 PM
kenji's Avatar
Hehehe.
123
Old May 8, 2006 | 12:18 PM
95GLEMAXX's Avatar
they seem more fragile than oem lights
Old May 8, 2006 | 12:22 PM
kenji's Avatar
That was my main concern.
Old May 8, 2006 | 01:15 PM
D-Bo's Avatar
Droppin logs
Originally Posted by kenji
Hehehe.
123
Don't be coy...
Old May 8, 2006 | 02:10 PM
JNCoRacer's Avatar
Just the tip.
DTM'd CE tails? I thought about doing this but nobody here has them on their car for me to do. They wouldnt fit my car, I just thought it'd be fun.
Old May 8, 2006 | 05:06 PM
kenji's Avatar
Bingo.
456
Old May 8, 2006 | 05:16 PM
Fr33way™'s Avatar
Wild for Width
Just try checking them sooner? Start off with a cooler temp?
Old May 8, 2006 | 05:27 PM
DR-Max's Avatar
Set the oven at 200 degrees, pre-heat it for 10 min. Then put the tails in for 7 min and check. Check one corner with a flat head screw driver, if it goes in and separates the housing easily, then take out the tails. If not, leave it in there for another 5 min and recheck.
Old May 8, 2006 | 07:36 PM
JNCoRacer's Avatar
Just the tip.
From a man who knows his tails. Good advice there.
Old May 8, 2006 | 10:53 PM
D-Bo's Avatar
Droppin logs
Nice choice Kenji, the contrast will look good on your ride. You're going all out this summer huh?
Old May 9, 2006 | 06:02 AM
Linkage23's Avatar
I know this has been talked about before but how is the fitment of the CE tails? I like the idea of the DTM to the new CE red/clears...interested in how this works out for you Kenji. Post some pics of the final product...
Old May 9, 2006 | 08:59 AM
kenji's Avatar
My birthday is this weekend. Hah. I should stop buying crap. Actually I had the tails sitting in my closet for like 6 months. I have smoked 1 piece cefiros too waiting for a sick xenon retro (for like a year now), too bad it's not near the top of my list. One of my stock taillights is broken so I figured when I install these I'll make them unique at the same time.
Old May 9, 2006 | 09:02 AM
kenji's Avatar
When you work as hard as I do, you need to indulge sometimes. I just got a 60 cent raise too, and my stock will be fully vested in 6 months. Then I can tell them to take this job and shove it and use the xx grand to pay for college. I've got 16 grand in stock as of last year.. and my next valuation is coming soon (new fiscal year is here). I'm hoping that I have over 20 grand now. That should be enough to pay off a hefty student loan should I need it for the ECE PHD.
Old May 9, 2006 | 09:19 AM
kenji's Avatar
So exactly how easily should the lense pull off? And has anyone even ever tried this with CM tails? Time will tell. I don't know if 200 degrees is gonna do it. It hasn't loosened up at all. I'll let it sit for a few more minutes.
Fedex just dropped off my Ksports.
Old May 9, 2006 | 10:09 AM
JNCoRacer's Avatar
Just the tip.
Ksports? Is that another mod that wont get done for a year?
If I were in your area, I'd love to help you out with those tails. Are you going to use satin or gloss black?
Old May 9, 2006 | 10:18 AM
kenji's Avatar
No, the ksports WILL go on. The heads and tails are just low priority.
I work 40-60 hours a week. + some college classes
Old May 9, 2006 | 10:59 AM
DR-Max's Avatar
Easily??? There's nothing easy about these types of stuff, you need patience...alot of it. If you rush and try to pry the lense off, it WILL break! If you feel some resistance as you pull the lense apart, stick it back in the oven. It doesn't matter how many times you stick it back in the oven as this process is done right when you do it gradually. Rushing things will only get you a cracked lense or two.
Old May 9, 2006 | 01:39 PM
D-Bo's Avatar
Droppin logs
Same here but with a daughter who lives with me half the time. I've got a pile of projects in the garage to go at this summer too. Work meet here we come!
Old May 9, 2006 | 07:28 PM
kenji's Avatar
Dude, seriously, maybe we should make a work meet sometime this month or in June. Get everyone in the PDX/Vncvr area to come
Old May 10, 2006 | 09:56 AM
kenji's Avatar
The build quality on these is definately not great. Already three little pieces easily snapped off (and it gets more fragile with heat too for whatever reason)
I'll have to superglue those pieces back on. I chose a single piece of the 4 to do this testing on, knowing this type of thing would probably happen. I wonder if custom maxima would sell single piece replacements.. I guess I'd have better luck finding them here on the org.
Old May 10, 2006 | 10:40 AM
DR-Max's Avatar
They got those things fabricated in Taiwan which explains its quality.
Good thing they sent me a defective set. I was able to return them and forget about it. Soon after, I got lucky and found a set of all-clears being sold in limited quantities by an org member. He had 15 sets I believe and they went fast.
Anyway I had originally inteded to DTM it, which I did. I painted the inner housing of tails with graphite wheel enamel. However, I made a mistake of reinstalling the inner reflectors. So now, you can't tell that they've been DTM'd. So just a reminder, when you do yours, make sure that you don't put the back inner reflectors otherwise your tails will look just like before. You might notice a slight darkening but it won't be as obvious.
This is how mine looks like:
Old May 10, 2006 | 11:16 AM
kenji's Avatar
I'm thinking about painting the outer-inner-part to match the smoked cefiros.
Part of the tail is flat, "parallel" to the lense, while part of it is recessed, housing the bulb. I wonder what it would do for the look to paint the flat part while leaving the inner recessed part reflective. I'll probably test it on just the clear part first. then I can always fill in the recessed part if it looks bad, and finally the black side if it's still no dice.
Old May 10, 2006 | 11:19 AM
DR-Max's Avatar
IMO, the way they made the innards of those tails are retarded! You have a small hollow square in the middle and then the rest of it is right up against the lense. Light distribution is not even, illumination pattern looks retarded. That is another reason why I returned those crappy tails.
Those tails will never illuminate as evenly as the oems or these aftermarket ones:
Old May 10, 2006 | 03:47 PM
kenji's Avatar
unfortunately im way past the point of no returns. i got these for 150 shipped in gd though, so i wont be heartbroken. My original plan which still may stand, was a 97 rear conversion, including a CF trunklid.
Old May 10, 2006 | 04:26 PM
DR-Max's Avatar
I was going to do the same thing you are doing when I got my CE tails. Somehow, I had a bad feeling about opening them up. Sorry you had to scrap these tails but I think you will be more happy with the 97+ trunk conversion + red/clear tails.
Old May 10, 2006 | 05:39 PM
JNCoRacer's Avatar
Just the tip.
Send them to me!! I'd like to see what I can do with them. You can have them back.
Old May 11, 2006 | 09:09 AM
kenji's Avatar
I'm not scrapping them. 4 pieces broke off (small) and I plan on supergluing them back on. My stock tail is still much worse, the entire center is shattered. no amount of superglue will make them right again. I don't plan on breaking any of the other 3 pieces
Old May 11, 2006 | 09:19 AM
DR-Max's Avatar
Superglue will fog up the plastic lense.
Old May 11, 2006 | 09:56 AM
kenji's Avatar
Oh? What would you recommend? These are really tiny pieces, like a third of a fingernail size, all the way down to just little chips. The largest is maybe half a finger nail.
Old May 11, 2006 | 11:30 AM
DR-Max's Avatar
I would use Testors Glue Plastic Cement, you can get it at a hobby shop. It's safe for plastic applications unlike the crazyglue.
Stagnet04
Sep 14, 2015 11:28 PM
Maxxx10
Sep 13, 2015 03:16 PM
Steven Orozco
Sep 12, 2015 10:41 PM
