code 01 11
Old May 8, 2006 | 02:29 PM
jaxima's Avatar
code 01 11
I've read about it, now what do I do about it? I can't find any info - please help me out guys!!!
It's the EVAP control system/flow error code
Old May 8, 2006 | 02:32 PM
D-Bo's Avatar
Droppin logs
Originally Posted by ECU Fault Code Sticky
0111
Diagnostic Trouble Code 0111 is detected when ...
- EVAP control system does not operate properly.
- EVAP control system has a leak in the line between intake manifold and EVAP control system pressure sensor.
Possible causes include ...
- EVAP canister purge volume control solenoid valve stuck closed.
- EVAP control system pressure sensor and its circuit.
- Loose, disconnected, or improper connection of rubber tube.
- Blocked rubber tube.
- Blocked or bent rubber tube to MAP/BARO switch solenoid valve.
- Cracked EVAP canister.
- EVAP canister purge volume control solenoid valve.
- Closed Throttle Position Switch.
- Improper connection of one-way valve.
- Blocked purge port.
- EVAP canister vent control valve.
This is a "jackpot" code. It points to so many possible causes as to be almost useless. It may be accompanied by another DTC which is more specific.
I'm working through an EVAP problem right now. What other codes are you throwing?
Old May 8, 2006 | 04:11 PM
jaxima's Avatar
before I replaced the knock sensor 2 days ago it showed 0302, 0304, and 0111. I reset the ecu after the install and today it came back on- only code now is 0111. "wtf?" I asked myself, this makes me sick. haha, what if I just take the evap canister OFF completely? what will happen? oh yeah, my cel will not reset now, it stays on.
Old May 8, 2006 | 09:11 PM
ImmaSquashYou's Avatar
i'm throwing i believe the same code. And you are correct, mine resets but then comes right back on when i drive for like .0000001 miles. its a dealer part only for like around $70-90. Just gonna have to change it....but i got more things to fix than that crappy evap thing. BTW, its located on the left side near your gas tank on the bottom..
Old May 8, 2006 | 10:29 PM
D-Bo's Avatar
Droppin logs
I've read the valve on it is often the culprit as well.
Old May 9, 2006 | 03:20 PM
jaxima's Avatar
i crawled under the car and beat the hell out of it and played around with the hoses and stuff, thinking it would help - but it didnt. oh well, i will be replacing the evap cnister too before long. thanks
Old May 9, 2006 | 05:25 PM
D-Bo's Avatar
Droppin logs
Yeah beating it probably just ensured more of the charcoal brakes down and gets into the system. When I disconnected everything the old charcoal poured out of the lines and canister. Definitely time for a new one but I still have to pull of the valve and check it.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
