idle problems & starting problems
Old May 11, 2006 | 04:41 PM
mechanicaljoint's Avatar
2 symptoms, but probably 1 problem? (95, 5spd w/ 165k mi)
symptom #1.
after i start the car, it will just die on me while sitting at a stoplight. no warning or anything. i can usually restart it immediately, but the acceleration for the next few minutes is a little herky-jerky. doesn't happen everytime, but it does happen frequently (twice today)
symptom #2.
sometime the car just wont start. it's turning over but no detonation. crank it 5-6 times for 20-30 seconds. then usually around the 6th time it will start to run rough (little tap of gas will usually set it straight then). happend twice this week...
ideas? i couldn't check the stickies so point me in the right direction if there is something there. flame away!
many thanks!
Old May 11, 2006 | 05:29 PM
spiff56747's Avatar
Could be the fuel filter, IACV, ECTS, or an alternator problem. When the car dies, do the lights start flickering and then it dies?
Old May 11, 2006 | 07:14 PM
no flickering. the tach just drops off like you turned the key off and some of the lights turn on and stay on.
ECTS?
Old May 12, 2006 | 03:53 AM
vvslavavv's Avatar
Engine Coolant Temperature Sensor .. i think
Old May 12, 2006 | 09:16 AM
Anii23's Avatar
It is your fuel pressure regulator.
Old May 12, 2006 | 10:14 AM
kelster23's Avatar
Are you throwing codes?
Old May 12, 2006 | 11:02 AM
crazy97's Avatar
Mine did this along with other problems resulting from a grounding issue. I'm not sure if grounding was causeing this but mine would sputter for a few seconds every once in a while until I replaced a whole bunch of stuff that is in a list in the begining of this thread here- http://forums.maxima.org/showthread.php?t=452286
One of these ended up cureing it:
-ECT sensor (engine coolant sensor)
-crank sensor
-crank ref sensor
-camshaft sensor
-ignition switch
Old May 12, 2006 | 01:00 PM
hang on...i'll pull the codes...duh on my part - should have done this first...
Old May 12, 2006 | 01:09 PM
jhammer22's Avatar
Mine hard starts every once in a while to, You hav to give it gas to keep it going then it smooths out. That what yours does?
Old May 12, 2006 | 02:06 PM
codes: 0304 (stupid KS) 0908 & 0103 - ECTS problems.
Haynes covers it as do the ECU stickies
long live the .org
Old May 13, 2006 | 06:30 AM
why? explain...
Old May 15, 2006 | 02:13 PM
ok...problem still not solved...
checked the resistance of the sensor cold & hot and it matches the specs. so i reset the ECU and drove it a bunch. CE light never came back on and car never stalled/sputtered.
yesterday, while driving (car wasn't fully up to temp - 1/2 way btwn cold & run temp) light came on and car sputtered, but kept going. no further problems. again, i checked the resistance - it was still in spec.
is it possible that there is a bad "spot" on the resistor that as the temp is going up (and resistance is going down) the sensor screws up and the ECU tries to compensate?
think i should just replace the sensor?
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
boomerbrian
Oct 31, 2018 10:25 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
trungg86
Sep 4, 2015 04:58 AM
