Down Pipe brace
Old May 14, 2006 | 05:32 PM
maxgp1029's Avatar
00vi Equipped.......
Down Pipe brace
After changing down pipe & header, i noticed a brace, 2 rubber things one on each side of the pipe. it is located right before it connects to the cat. does anyone know if it hooks on to the heat sheild? I hope not it kind of had to get cut off
Old May 15, 2006 | 12:09 PM
maxgp1029's Avatar
bump.......no one knows?
Old May 15, 2006 | 12:55 PM
DJ420's Avatar
Bad Mother Fornicator
This is your cat hanger.. it does not connect to the heat shield at all. This brace is used to support the exhaust, and eliminate stress on the flex section of your front pipe.. I do not recommend you remove this, however if you must, try to brace the exhaust somewhere in that vicinity somehow, or else your flex section may wear quite prematurely..
DJ
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
