How do I adjust my hood?
Old May 15, 2006 | 11:33 AM
projectpete's Avatar
my car got in a fender bender and now the hood is missaligned. The gap on the left side (between the hood and fender) is smaller than the one on the right.
How do I adjust it so they are even on both sides? I tried loosening the two bolts holding the hood to the bracket but that didnt work. Also, the hood and the latch matches fine.
Old May 15, 2006 | 12:39 PM
DJ420's Avatar
Bad Mother Fornicator
The bolts from hood to hinge have no adjustment, you need to adjust at the bolts from hinge to body. Unfortunately, access to these bolts requires that you remove the fenders, as no wrench that I am aware of will fit in the tiny amount of room they left..
The EASIER way to do it, would be to once again remove the bolts from hood to hinge.. THEN using a dremel tool or equivelent, elongate the holes in the hinge a bit, in the direction that you need to move the hood. This will allow you some adjustment room, when you replace the bolts.. and you can get it where you need it, then tighten them up nice.
DJ
Old May 15, 2006 | 12:58 PM
Rit's Avatar
Rit
hoodie
Can you just loosen the bolts that hold the fender on (you see them at the top, when the hood is open) and slide the fender towards the hood - on the side with the bigger gap. I'm just guessing on the Max, but I've done this on other cars.
Old May 15, 2006 | 02:21 PM
DJ420's Avatar
..you may, but it looks tight in there. I dont want to advise anyone to bend it back..
DJ
Old May 15, 2006 | 02:25 PM
JNCoRacer's Avatar
Just the tip.
I was able to do that on my wife's 98 Max. It only needed to move less than 1/4 inch though.
Old May 17, 2006 | 03:54 AM
DJ420's Avatar
Oh ok I get what yer saying now.. sounds logical. But what do you do if theres a gap on one side, and the other side is so close its just about touching? Pull the fender OUT on that side??
DJ
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
AaronL
Aug 8, 2020 10:31 AM
leatherneck
Sep 30, 2015 09:16 PM
