Tensioner and Guide *Pics*
I remember reading about there being two different styles of the tensioner and guide. There was and old style and a newer style.
In terms of installing there is no difference correct?
Also which one do I have, not sure if its the old style or the new style, thanks.
Front
Back
Front
Back
Originally Posted by kcryan
pm sent.................
yikes. . .
its like #3 on fast . . the alternative but 26 instead of 25. I guess I'll find out when I put it on. . .
I'll keep the right part number on hand incase this should not fit.
Well the way David B the parts guy explained it to me is, the new tensioner is to large to fit through the door like the old one did...you need to remove the entire cover to get the tensioner in.
part #'s
# 1307031U00
# 1307031U01
Bad New part number is 31U26
Old part number will be 31U00 or 31U01 and Will fit
The tentioner that wont fit and requires the entire cover to be removed is the 31U03 or the 31U26 which is the kit.
**DAVID BURNETTE IS MY COURSE FOR ALL THIS INFORMATION***CALL HIM FOR MORE INFORMATION**
-matt
part #'s
# 1307031U00
# 1307031U01
-matt
well as long as it still fits that is fine. I plan on putting this on when the motor is out of the car so that factor isnt a big deal just as long as it will fit.
So from what I've gathered its just the old style that could be installed without removing the timing case, the new part requires the timing case removal. But both parts once installed both work just fine.
Thanks for the info this clears up some things for me.
part #'s
# 1307031U00
# 1307031U01
-matt
part #'s
# 1307031U00
# 1307031U01
-matt
OLD TENSIONER//OLD GUIDE
NEW LONGER STYLE TENSIONER//OLD GUIDE
PICS thanks to JIME....This is the NEW style Tensioner, with the Old Style Guide in a 4th gen
The
No guys, these part numbers just recently changed. Nothing to do with the stock part number. They are all, from 95-99, the SAME EXACT part number.
The larger Tensioner was just changed last year from fix from Nissan. This has Absolutely Nothing to do with Production dates at all
-matt
-matt
Guess I better start looking for an old one.........
From the looks of it, finding one will not be easy.
I forgot to mention last night that the dealer I spoke with gave me the 13091-31u26 as the old part. He told me they had another one with the #13070-31u0a. I do not know if this is correct. He also told me that I could just change out the tensioner with this one. I also do not know if this is correct, reason I came back on here to check. Maybe someone here could look into it. I will do some digging at lunch time.
**Edit**
Has anyone tried going the aftemarket route for this? What about getting one from a used engine at the junkyard?
**Edit**
-matt
Here's a thought..inside the tensioner, there's an o-ring that basically seals the piston & bore. This way when oil is forced into the tensioner chamber, it pushes the piston out against the chain guide. I grabbed an o-ring from my mechanic that was an exact replacement. I'll be putting it in when I get some time & report my findings.
I was one of the first guys that replaced my old tensioner with the new one (twice), and only realised that they were different after the fact. It worked in the sense that it got rid of the start-up noise, but as you can see in the pics, it ain't pretty.
I just finished speaking with one of the parts guys at a dealer here in town. The guy was actually trying to help me and was on the phone with me for a while. He told me the new number, 13070-31U0A, also requires the changing of the guide. I guess I can try getting the Autozone tensioner and see if it works. The shop I go to quoted me $400 dollars labor to change out both the tensioner and the guide. I think this is not that bad for all the labor involved. They had quoted me $175 dollars to change out the tensioner out the door. They were going to use the OEM one though. I will take the Autozone tensioner and they will check to see how it measures up to the old one. Hopefully the aftermarket one goes in....
Edit:
This is the link and picture to the one from Kragens. It looks like the revised version.
http://www.partsamerica.com/ProductD...pe=462&ptset=A
Edit:
Just for the record, the new redesigned tensioner WILL fit in the access hole without removing the entire timing cover.
But what's the point? You have to remove the entire cover to install the matching guide, so it does you no good at all.
-matt
[QUOTE=matty]Well the way David B the parts guy explained it to me is, the new tensioner is to large to fit through the door like the old one did...you need to remove the entire cover to get the tensioner in.
I am simply trying to clear up the misinformation from Dave B that you posted earlier.
Because it is simply not true.
-matt
Originally Posted by mzmtg
Can I install the spring and/or piston and/or O-ring from the new tensioner into the old tensioner body?
There's no way I'm taking my timing cover off. Ever.
Hmmm, would be good to know. Having some issues with yours too Ben?
If I can't swap the new bits into the old part, then I'm just going to put in the new tensioner with the old guide and live with it.
I started noticing the noise only while driving. This happened within the last month or so.
Keep us posted on exchanging out the new bits into the old part. I would much rather go this route.
I "rebuilt" my old tensioner using the plunger, spring and seal from the new one. It all fit right together.
Of course, I dropped the plunger in the timing chaing cover while removing the old unit. Luckily, I was able to fish it out with a magnet on the first try.
