IACV Differences
Old May 16, 2006 | 01:28 PM
ti2tmax's Avatar
Has his VINs memorized
IACV Differences
I purchased a used IACV and it's different from the one on the car. There's a second smaller sensor on the other side of the larger sensor that my car doesn't have. It appears that mine has a sort of "bung" to plug it. I'm going to see if I can take the sensor and swap it with the bung without any issues. Anyone have any experience with this or other info that would be helpful? Thanks!!
Old May 16, 2006 | 03:28 PM
XeroX's Avatar
Hella internets
Post pics...are you sure your not confusing the idle adjustment screw with a plug? i believe there should be a large Grey plug, a pink plug, and a purple one...so its a total of 3....
Old May 16, 2006 | 04:01 PM
maximaintheface's Avatar
it sounds like either u got the wrong one or your missing your idle adjustment screw. liek he said post a pic and we will be able to tell you really fast what is wrong.
Old May 16, 2006 | 05:37 PM
RA030726's Avatar
I'm nutty for Nissans
What color is the sensor? And yea ditto on the pix.
Old May 16, 2006 | 05:46 PM
ti2tmax's Avatar
unfortunately I can't upload the pictures I took, my computer freezes up every time, I can try emailing someone. My car only has (originally) two plugs on the actual IACV, plus the one that mounts on/near it. The new one has three on it, on near it. Two smaller ones and one larger brown one. My original one has a plug where the sensor would go in but there's a small part that doesn't come out.
Old May 16, 2006 | 05:47 PM
ti2tmax's Avatar
Oh, the new/used one I purchased is from a 95 auto GXE cali spec and my car is a 99 5spd SE Cali spec but it has one less sensor...
Old May 16, 2006 | 05:49 PM
ti2tmax's Avatar
Ok, it looks like my email will let me if someone wants to let me send them the comparison pic and post it for me that would solve some confusion.
Old May 17, 2006 | 04:25 AM
RA030726's Avatar
jsutter101@netscape.net send it on over!
Old May 17, 2006 | 06:56 AM
ti2tmax's Avatar
Ok, sent! The IACV on the left in the pic is the one that was on the car. The one on the right is the one I put on the car after unscrewing the plug and sensor and switching them, but it still didn't seem quite right as the one with the sensor was a flow through hole. THe one on the car with the plug had a secondary shiny plug that wouldn't come out. May send a couple more pics JSutter
Old May 17, 2006 | 07:09 AM
ti2tmax's Avatar
No, it's def. not the adjuster screw. I don't know if I wrote back on here that I did end up haveing to get the car to move so I switched the sensor with the plug on the two IACVs and put the new/used one on the car and it works. It didn't seem to fluctuate the idle like normal, but I didn't take it for a drive yet.
Old May 17, 2006 | 09:34 AM
XeroX's Avatar
Hella internets
If you want you can send me the pics and i can host em for you if you figured out how to get em on the computer.
Jahoosapheth@gmail.com
Old May 17, 2006 | 12:32 PM
ti2tmax's Avatar
Well, had the opportunity to drive it about 30 minutes this afternoon and it seems MUCH better, but it still doesn't seem quite right. She still studders on decel but the bucking on light accel has disappeared all together. I'm not sure if what I think is still not right on it is an idle issue or wether it's my axles(NAPA remans)
Old May 17, 2006 | 04:00 PM
RA030726's Avatar
the pink one is the fast idle for power steering
the purple one is the fast idle for air conditioning
they turn up the idle to compensate for the extra load when those accessories are on.
Old May 17, 2006 | 07:16 PM
ti2tmax's Avatar
So why do you suppose my car doesn't have both, as it does have PS and AC.? Man, 99s are just crazy different I guess!!
Old May 17, 2006 | 07:30 PM
RA030726's Avatar
that 95 didnt have A/C, either that or it was such an early model they didnt see the need to have that fast idle.
Old May 17, 2006 | 07:33 PM
ti2tmax's Avatar
well, the one from the 95 is the one with both sensors. The one from my 99 is the one which has only the one small sensor...
Old May 17, 2006 | 07:34 PM
ti2tmax's Avatar
So it hasn't altered driveablity but I'm curious about finding this out now
Old May 18, 2006 | 04:30 AM
RA030726's Avatar
2 on the 95 and 1 on the 99!? wow thats weird. Well then it should be fine if the a/c fast idle stays closed. i wouldnt worry about it either way.
Old May 18, 2006 | 07:19 AM
ti2tmax's Avatar
Yeah, it's changed slightly in the right direction so I'm satisfied. I'm curious though because it didn't have a gasket the first time I took it off so there's a possibility that something happened before I got her... Maybe I should take the person offering $1 Vin checks up on it...
mkaresh
Mar 12, 2018 06:48 PM
doctorpullit
Dec 12, 2015 09:39 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Pied
Sep 26, 2015 03:29 PM
