Harness Wire Switch
Old May 19, 2006 | 09:40 PM
DragonMaxima's Avatar
Harness Wire Switch
Trying to switch the wires around so my HighBeam Indicator light is not constantly on. What's the best way to do this? Right now my current harness looks like this-
I need to change it to this-
Tools needed? Special instructions?
Thanks.
Old May 20, 2006 | 09:07 AM
clive's Avatar
100% chingon
Slide a narrow blade into the part where the wires enter the connector. Look carefully and you will note that there is a flexible 'springy' bit on the metal connector pin, that stops the metal pin being pulled out of the hole. Depress that with the blade and you should be able to pull the pin out complete with the wires attached. Just takes a little bit of patience and good eyesight.
Old May 20, 2006 | 08:14 PM
Thanks alot. Just the information I was looking for.
Old May 20, 2006 | 08:30 PM
MDeezy's Avatar
HID kit caused the light to be on?
Old May 20, 2006 | 08:32 PM
Yes sir.
Guess I got a Universal Harness for 9004/9007 & H4
9aj9
Apr 5, 2020 12:11 AM
Kingofmaximas24
Nov 12, 2015 04:40 PM
Maxie40
Sep 14, 2015 11:28 AM
