altima ser brakes
Old May 23, 2006 | 05:27 AM
appleman's Avatar
altima ser brakes
are they worth putting on our cars. are they much better?
Old May 23, 2006 | 06:04 AM
NmexMAX's Avatar
dot dot dot ...
Depends on what you think is better. Check Mattblehms page for better info. Jeff92se also has some kits available. Or get raped by Stillen.
There are many choices out there, just need to search the forum a little bit.
And dont let the SE-R fool you, they are just snazzy looking A34 brakes.
Old May 23, 2006 | 06:29 AM
appleman's Avatar
ok,i know that they are a34 brakes but do they stop better? are they 2 piston as compared to 1
Old May 23, 2006 | 09:13 AM
Maximus_95's Avatar
i think they are 2 piston but, since it is a new kit, it will be way more expensive and i dont think its worth it.
go for the 300zx kit.
Old May 23, 2006 | 09:20 AM
NmexMAX's Avatar
dot dot dot ...
A34 = 1 piston. They have better brake torque due to larger rotors.
I got my 'kit' on my A33B for less than 300$.
But, you would have to check out Matts page for further details re: the entire kit to support your A32. IIRC you can use the A34 rotors with your stock calipers provided you purchase some relocation brackets from him.
Old May 23, 2006 | 09:36 AM
appleman's Avatar
ok well id be going to take the calipers and all associated parts off a wrecked altima. so i can take anything i would need. i will get these parts for very cheap. do you guys think its a good idea
Old May 23, 2006 | 10:01 AM
NmexMAX's Avatar
dot dot dot ...
http://www.mattblehm.com/brakes.htm
I'd take the engine before I took the brakes.
Old May 23, 2006 | 06:49 PM
appleman's Avatar
ok guys thanks for the info BUT i need to replace my rear calipers so would the ser rears bolt up. what about the fronts?? i need an answer asap as im goin tomorrow to get the parts that i want. it is a full car that was wrecked? anything else i should take???
Old May 23, 2006 | 09:34 PM
NmexMAX's Avatar
dot dot dot ...
Email Matt Blehm, he WILL get back to you in a timely manner and answer your question(s). Had you done this earlier, you might have got an answer faster since you need it ASAP, but you keep asking redundant questions about the front brakes because either you havben't read the previous posts, or are just plain stubborn.
Any one of these 3 links will work. There are email addresses that may help you get in contact with him so that you can ask him more questions, as sated earlier.
http://www.mattblehm.com/brakes.htm http://www.mattblehm.com/brakes.htm http://www.mattblehm.com/brakes.htm
As far as I know re: the front brakes..
The reason for the calipers not fitting properly is because the rotors are small on A32's and do not leave enough room to fit the larger ones.
Since you keep asking, why don't you take the engine?
If things are free, take all you an get. Not sure about the rear brakes
Old May 24, 2006 | 09:44 AM
zander's Avatar
take the engine, tranny, ecu, harness, everything needed to get the car moving. If you can't use it Im sure you could sell it here or on b15sentra.net or thevboard.com, sentra guys love the engine too.
Apr 16, 2020 05:15 AM
doctorpullit
Dec 12, 2015 09:39 AM
BobTX10
Oct 7, 2015 08:43 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
