tried cleaning the TB
Old May 28, 2006 | 01:09 PM
Mr Willis's Avatar
Now my car is hesitating bad. I pulled very hard on the intake part's just to move them around and i think i may have damaged something. My bulging python biceps may have cracked something. LOL
Seriously Any ideas guys?
Old May 28, 2006 | 01:28 PM
CRiME's Avatar
oem ftw!
the first thing you should do is go over what you did and recheck all connections, ie MAF connector, etc. make sure everything is tightened up and that you didn't forget to reconnect any hoses.
Old May 28, 2006 | 01:44 PM
Mr Willis's Avatar
Did that a couple times and everything seems fine. Thanks for the response.
Old May 28, 2006 | 01:48 PM
CRiME's Avatar
oem ftw!
that's wierd, what did you use to clean it? i used gumout and it worked great. did any of the spray come in contact with the MAF by any chance? if so, that could cause the problem you're describing
Old May 28, 2006 | 01:49 PM
99se5speed's Avatar
SHIFT_up
what did you use to clean it? Maybe you used to much of it, or something might have messed up the MAF...
Did you just clean like the butterfly and the area around it or you just sprayed the crap outta the TB to clean it?
Old May 28, 2006 | 02:55 PM
Mr Willis's Avatar
I took off that flex tube and just wiped the TB with a rag. I didn't use any spray actually because it didn't LOOK dirty.
Old May 28, 2006 | 08:02 PM
konak85's Avatar
probably a vacuum leak
Old May 28, 2006 | 09:10 PM
Fr33way™'s Avatar
Wild for Width
Sell the car.
Old May 28, 2006 | 09:14 PM
D-Bo's Avatar
Droppin logs
Originally Posted by Fr33way
Sell the car.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
