What is the fuse number for fuel pump?
Old Jun 18, 2001 | 04:48 PM
zaebis
Does anybody know what the fuse number is for fuel pump circuit? I know it is blue 15Amp but there are many blue 15 amps out there. So what is its number ?
Old Jun 18, 2001 | 06:27 PM
Mishmosh's Avatar
I think it's 32, if I remember correctly. Also, doesn't the fuse hatch have the fuse mappings on the back?
Old Jun 18, 2001 | 07:09 PM
Daniel B. Martin's Avatar
The fuel pump circuit is powered by two fuses ...
#17 (10 amps)
#32 (15 amps)
The passenger cabin fuse block is located behind a pull-out panel in the lower dashboard, to the left of the steering column. It has three columns of fuses.
Numbered from bottom to top....
- the left-hand column contains fuses 1 - 11
- the middle column contains fuses 12 - 26
- the right-hand column contains fuses 27 - 40
The numbers are molded into the plastic fuse block. They are not easy to read. A flashlight will be helpful.
Old Jun 19, 2001 | 09:04 AM
zaebis
#17 (10 amps)
#32 (15 amps)
Thanks. But does that mean I have to take out both of them to cut out power for the fuel pump?
Old Jun 19, 2001 | 10:13 AM
Pulling either fuse will disable the fuel pump.
BkGreen97
Apr 2, 2016 05:47 AM
cruce91
Sep 20, 2015 10:23 AM
bumpypickle
Sep 20, 2015 08:22 AM
conansriver
Sep 11, 2015 10:26 AM
