Can I pull a boat?!?!
Old Jun 29, 2006 | 12:00 PM
  #41
O_Rly's Avatar
Originally Posted by dgeesaman
I think it should be made clear that the guys who have a hitch on their Max appear to be well within the recommended weight limits for a Maxima. The original question involved a considerably larger boat and also the question of negotiating a pull up the boat ramp. It's those elements that make the Maxima unsuitable.
Maximas are perfectly fine for pulling small loads, as long as traction and total weight are not a problem. It's certainly less effort for the car than when it's loaded with cargo and people, yet nobody worries when that happens. You can always gear down for more torque, and of course the hitch can be bought as a removable type so that it isn't visible. In fact, I'm considering a hitch not for my Maxima, but for my RX-7 - just so that I can tow a small tire trailer to racing events.
It's not that towing a Maxima or other car is bad, but you have to know its limits and really respect them.
Dave
Cargo/people don't put stress on the frame directly. Gear down for more torque, in a FWD vehicle that doesn't have alot of torque to offer for towing to begin with. Either way- the car is geared for commuting/gas mileage-ie longer gears, not for towing-ie shorter gears.
Removable hitches still leave a visible reciever. If your car ever has to be towed its something else to worry about clearance wise.
Old Jul 22, 2006 | 08:24 PM
  #42
† ErV †
the maxima has enough power to pull anything, thing is you can neither get the traction, nor the structural strenght to do so.... if only power made things go, then we would have tricycles with hitches
Old Jul 23, 2006 | 12:00 AM
  #43
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Go for it. I towed an rx7 with my car, thats about 3000lbs and we didnt have any problems....except for some snapping tow cabels, hehe.
Old Jul 23, 2006 | 03:21 AM
  #44
dgeesaman's Avatar
Maintenance Monster
LOL, care to explain then *what does* transfer load from a hitch or car seat or trunk floor to the suspension? It ain't the gas tank or body panel
Dave
Old Apr 9, 2010 | 09:03 AM
  #45
GT74's Avatar
Ok guys, so its too long to ask on this thread, I didn't found a thread better than this one so my question goes....
I am moving from CT to TX and planning to tow my stuff with my 97 Max, stock, considering 500LB of passenger + cargo weight, how much should I tow maximum ( trailer weight + Cargo weight ) safely, and what it can be detrimental to my car for this one time hauling of around 2000 Miles....I simply checked U-haul option and one way is costing me 2 grands (U haul truck + trailer to tow my car), I baught Maxima in 2007 for $ 3700 , it already has 145K mile on it....will appreciate response...
Old Apr 9, 2010 | 09:12 AM
  #46
Quickywd01's Avatar
Check the owners manual, it might have this info.
Old Apr 9, 2010 | 10:46 AM
  #47
SiathLinux's Avatar
As much as the OP has already stated that he's changed his mind on this - a couple of things to consider.
FWD and boat ramp - honestly the front tires are on dry ground - load balance would be the only issue with traction. I still wouldn't recommend towing anything with your Maxima since it wasn't really designed for having a hitch...
Toyota Trucks are ok - but you should consider an UPGRADE to a Nissan Hardbody/Frontier truck for you towing needs.
and on that subject I've seen a Hardbody with a VG30DE swap - nice wide tires and a class 3 tow package... They had no problems towing a 16' Cobia with a 75hp Merc Outboard (can we say heavy boat, with heavy motor) -
Old Apr 9, 2010 | 10:49 AM
  #48
cashoit's Avatar
u can tow a trailer no problem. the VQ got more than enough power
Old Apr 9, 2010 | 11:01 AM
  #49
NIGHTMAREuki's Avatar
guys this is not a question of sufficient engine power. its about safety.
tires and brakes are the concern in this case.
I think its would be ok to tow ~700lbs
Old Apr 9, 2010 | 05:55 PM
  #50
SiathLinux's Avatar
The OP was referring to a 3,000 lbs boat/trailer combo... which in my experience is a bad idea on a front drive car, especially one not designed to have more than a class 1 hitch (which isn't recommended either)
Old Apr 9, 2010 | 07:24 PM
  #51
abhirud07's Avatar
V10 Touareg TDI by VW. you can tow a 747 with it
Old Apr 10, 2010 | 07:21 AM
  #52
max96imaaaa's Avatar
First, I've seen a post around here where this guy has a sweet maxima, maybe even a swap engine and he tows a big @$$ boat. I dont have time to search for the thread but its here on the org.
Second, I have a hitch on my car for towing bikes on a rack. Three bikes to be exact at about 30lbs a bike, plus the rack is about 100lbs on the tounge. You can tow whatever you want, I'd just pay close attention to the tongue weight. Make sure it's about 200lbs or less. You may have to have the axels moved on the boat trailer to balance it better. My family and I have done a lot of boat towing, everything from my 14' Jon Boat to 26" twin engine beasts...
You will be fine towing with the max for short trips(roundtrip under 20miles). I wouldnt open highway tow for hours. The launch ramp as others said is a big consideration, you may need more weight on the front end(ie friends on the hood). As i've seen a bunch of times---the ramps get wet and slick as H&ll---YOU w/ FWD will be losing traction!
I would drive it gingerly to say the least. And btw, I plan on towing a Jon boat w/15hp yamaha on a trailer this summer when I can find a deal.
Old Apr 10, 2010 | 07:36 AM
  #53
edwardh1's Avatar
MAximas have marginal brakes, one reason they are not rated to tow, Nissans in general have marginal brakes (warping rotors etc)
HerpDerp1919
Sep 29, 2015 02:02 PM
Sep 27, 2015 08:37 AM
