damn brakes
Old Jun 11, 2006 | 03:04 PM
GStrength's Avatar
damn brakes
on my 96 gle and 97 gxe i changed both front brakes. when i put my car in reverse and let go of the gas to press the brake, i hear a click noise, one solid slight gunk sound. it happened to both maximas of mine i'm using autozone's duralast brakes, any suggestions?
Old Jun 11, 2006 | 03:17 PM
GStrength's Avatar
i bled the lines too
Old Jun 11, 2006 | 04:35 PM
GStrength's Avatar
ok i guess no one has a clue thanks though imma just delete this thread in 5 more minutes
Old Jun 11, 2006 | 08:10 PM
sergey85's Avatar
i have the same problem i just changed my brakes with the duralast gold and the rotors from autozone, i didnt bleed the back but i hear the same noise from the back when in reverse
Old Jun 11, 2006 | 08:34 PM
xlr8r's Avatar
I can tell you all the thing's I did wrong with brakes over the years and maybe one will hit:
leaving out the clips - the pads are loose in the calipers and this causes all sorts of nasty braking problems - much worse than a "clonk"
shearing the metal tubes out of the rubber bushing brake caliper to hub slides (this was a honda) this made the brakes clonk like you say.
leaving the shims off because I couldn't get the pistons in far enough but this just makes them sqeal.
The clonk sounds like there's some play in the brake assembly. In normal motion you're biasing the brakes in a forwards direction. When you hit the brakes the assembly shifts back due to braking force.
Check that everything is tight, moving smoothly, appropriately greased and complete.
If it just started after the replacement job, then it must be something simple. Retrace your steps.
Good luck!
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
