recommended oil filter?
Old Jun 13, 2006 | 12:22 PM
bigherm033's Avatar
i am about to change my oil for the first time and i was wondering if buying a K&N Filter would be better than buying standard filter b/c i have an oldercar with 160,000 and i want my baby to last.
what oil filter do yall think is best worth the money you pay for it
Old Jun 13, 2006 | 12:39 PM
NCSU_MAX's Avatar
Maximoneypit
K&N is good, even though a bit pricey - thats what I have. OEM is also good. Check out the fluids and lubricants forum - theres some good info there on this stuff.
Old Jun 13, 2006 | 12:45 PM
udienow's Avatar
does it really matter? I really dont think it does as long as you change the OEM oil filter every 3mo/3k miles.
Old Jun 13, 2006 | 02:07 PM
99grnmaxgxe's Avatar
Visit the stickies in the Fluids and Lubricants forums. From what I read the one to stay away from is the Fram.
Old Jun 13, 2006 | 02:14 PM
dgeesaman's Avatar
Maintenance Monster
K&N is a complete waste of money. Ditto with the Mobil1 filters.
Anything better than the cheapest in the store or Fram standard filters is fine. The most important thing for your engine is to change the oil and filter more often. I change the oil and filter together at 5k, and use Mobil1 10w-30 oil. When I run dino oil I change at 3k and use a new filter each time. My car has been on this diet since 45k (it's at 150k now) and it burns less than half a quart each 5k.
The best value of the premium filters IMO is by far the Bosch Premium. If you take it out of the box, you will notice it's absolutely identical to the Mobil1 but at half the price. The maxima size filter runs around $7. In fact, for a time Mobil1 and Bosch both used to cite the same filtration test results on the box, but I think Mobil1 got wise, rebadged the filter and made Bosch remove the filtration test values. So you still get a Mobil1 filter at half price.
Dave
Old Jun 13, 2006 | 02:18 PM
Ceasars Chariot's Avatar
Old Maxima Legend
do get the k&N filter or replace old filter if dirty, and swing by the local nissan dealership and pick up the oem nissan filter should be around $ 5.75 - 6.75.
Nissan OEM Oil Filter PT#: 15208-9E000
Old Jun 13, 2006 | 04:33 PM
maximaSE327's Avatar
Dave
interesting to know... ive been using mobil1 5w30 w/ mobil1 filter since ive owned it... ill try the bosch next time to save me some coin
Old Jun 13, 2006 | 06:38 PM
MrDicks95SE's Avatar
Offset Is Everything.
go to your local dealer and get an OEM filter. dont forget the washer too.
Old Jun 13, 2006 | 07:00 PM
z32drifter's Avatar
I've run alot of filters over the years, and I'm happy to say I've never had a failure. I change the oil 3k with synthetic.... overkill?? yes but it's cheap protection for my motor. Here are a link to check out, good independent info.
http://minimopar.knizefamily.net/oilfilterstudy.html
Old Jun 13, 2006 | 07:06 PM
Fr33way™'s Avatar
Wild for Width
I use a Bosch.
It filters at 98.2% while Mobil filters at 99%, for half the cost.
Just keep your intervals low and it really wont matter what's on there.
Old Jun 13, 2006 | 07:18 PM
SNOMAX's Avatar
PM me for LCA's!
Well, this is only my subjective opinion, but... Oil filter (i.e., paper filter) technology doesn't have a lot of places to go. I mean... most filters are about the same. Changing the oil often is the best option and to some degree the filter as well.
If you want to see how effective the filter is, get a snap on magnet for the oil filter, or just get a really stong magnet and duct tape it on the filter. Drive for 3000 miles or so, change filter, and cut open oil filter.
Metal shavings should be on the magnet. The less shavings, the better your oil protection and filtration system is.
I have heard stay away from Fram, but that's just based on a few posts I have read. I would say buy a basic filter, like OEM and be done.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Fbana41
Aug 29, 2016 12:18 PM
f.matejaiii
Sep 21, 2015 12:09 PM
