upper intake manifold bolt
Old Jun 15, 2006 | 12:29 AM
maximaintheface's Avatar
i cant get the upper driverside bolt. it snaped in the middle for sure i can spin the top but if i feel the bottem of the bolt it doesnt spin like the other side. also its a bit crooked like it was torqed to tight or somthing. im idling high and i think that might be why. how would you go about getting that bolt out.
Old Jun 15, 2006 | 04:30 AM
RA030726's Avatar
I'm nutty for Nissans
Which bolt is it specificly? One that holds the upper to the lower?
Old Jun 15, 2006 | 10:54 AM
yes. the one on the driver side.its the one that looks wierd its not the same as a regualr bolt.
Old Jun 15, 2006 | 11:17 AM
tavarish's Avatar
fwd gone rwd cr00
if the bolt thread is stuck and the bolt top spins, drill it out and then tap it.
Old Jun 15, 2006 | 12:36 PM
RA030726's Avatar
The end ones are studs with a nut on them. The tip of the stud looks like a torx bit. They make female torx sockets for removing them. If you dont have that tool and if there is enough thread sticking out (probably not), you could thread on another nut tightly against the original. Then you can turn the original one with a wrench. I took out the stud with a 12 point socket in the past.
Old Jun 15, 2006 | 01:36 PM
tried with a 12 pt socket but it wont come out. and the top nut does spin but will not come off. so if i have enough thread i should put a nut on it then get say a box wrench and try just spining the origonal bottem nut ?
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
JonBlz
Oct 5, 2015 06:02 PM
dshinn
Sep 26, 2015 08:07 PM
