Door panel removal Part 1
Old Jun 19, 2006 | 06:04 PM
RockfordMax's Avatar
Back from the dead
Alright, I noticed the links in the How-To's are dead and removed, so I figure why not share the knowledge. First of all, this may seem like a hard task at first, but it is much easier than you think. I took it off and replaced it in less than 5 minutes to take these pics. With that said, let's get underway.
This is the standard 4th gen doorpanel. Colors change, but (save for a tweeter in some) exactly the same from 95-99.
The only tools you will need for this are a flat, and a phillips screwdriver.
The first screw to remove is in the door grip. It is a phillps head, however you could use a 6mm socket to remove it. After that, remove the 2 small screws that hold the light to the door panel(this is not necessary, but is easier and removes risk of damaging wiring later.
After the screws are out, unplug the harness from the light. Put it somewhere safe!
After that is complete, remove the 2 phillips head screws below the door pocket.
Old Jun 19, 2006 | 06:17 PM
ThurzNite's Avatar
Wow, nice, good sticky
Jae
Old Jun 19, 2006 | 06:20 PM
Black Maxima
Good job. And changing the window glass is pretty easy too.
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
Stelianos
Aug 19, 2015 02:07 PM
Abdelrhman
Aug 17, 2015 12:16 PM
kirkhilles
Aug 8, 2015 10:53 AM
