Car loses Voltage
Old Jun 22, 2006 | 04:03 PM
Maximus_95's Avatar
Car loses Voltage
ok guys, the other day, i was driving around and whenever i steped on my brake pedal, all my lights would dim, my rpm would drop nearly stalling and then pick itself back up....
Can anyone help me out?
it only happens when i step on the brakes.
if i turn off the car for a couple of secs, if im lucky, it goes away, but it comes back later on the day.
Old Jun 22, 2006 | 06:40 PM
Motorhead52's Avatar
CHeck all the wires from the battery out, espcially the ground around the transmission and starter assembly.
Old Jun 22, 2006 | 07:19 PM
GarciaMaxima's Avatar
my car was doing that a while ago.
It turned out to be a loose alternator connector (i must have moved it when i was cleaning my engine). But motorhead's suggestion is very good. Check all your cables from the battery and ground
good luck
Old Jun 22, 2006 | 07:28 PM
HarrisH's Avatar
Immediatly check the the easiest thing first. The "ALT. S" fuse located under the hood in the thing rectangular shaped box next to the battery. This controls the alternators signal.
Then check the alternator's connector, clean with a strong brush wire and spray some carb. cleaner in it. Make sure it "clicks" back into place. While inspecting that harness make sure all the wires on it are in GOOD condition.
If all else fails put a voltmeter on the battery with the car running, put a load on the car, the voltage should stay consistent between 13.xx and 14.xx preferrably between mid to high 13s close to 14s. If the voltage is not within that range your alternator is failing, the regulator, or diode in it is probably out.
Do yourself a favor. PURCHASE ONLY A BRAND NEW OEM ALTERNATOR AT ALL COSTS.
Old Jun 23, 2006 | 03:20 AM
Black Maxima
I get the same problem. It still does it after I installed a new alternator.
Old Jun 23, 2006 | 07:54 AM
Wetballoon's Avatar
Black Max, have your battery tested. And Maxima 95, you should consider is also. The major parts chains will do it for free, but the battery must have a full charge when they do it. They will also test your alternator.
Old Jun 23, 2006 | 01:14 PM
Black Maxima
Do I have a replacement warranty with my Duralast AutoZone battery?
Old Jun 23, 2006 | 02:32 PM
Maximus_95's Avatar
i checked the battery, its pretty good, all connections are tight.
gotta check the alt. connections.... thanx guys.
Old Jun 23, 2006 | 03:36 PM
blkhawk500's Avatar
If its only doing this when your stepping on you brake it might not be an alternator problem. You might try your brake check valve. Its located on the hose leading to the brake booster.
Old Jun 23, 2006 | 04:00 PM
Black Maxima
Mine is fine. I can blow through it.
Lakersallday24
Jun 16, 2019 01:35 AM
JMag90
Aug 25, 2015 09:17 AM
doobadoo
Aug 15, 2015 06:43 PM
acw
Aug 13, 2015 12:50 AM
acw
Aug 7, 2015 04:20 PM
