poorman torque wrench
Old Jun 24, 2006 | 07:41 PM
xlr8r's Avatar
Gah! getting ready for big front end rebuild and I find my torque wrench only goes to 150ft-lbs and I need 174+ for the axle nut.
Now I weight 175-185lbs. If I was to stand exactly at 1ft on my breaker bar would that be good enough for torquing the nut back on or does this need to be super-accurate? How about guessing the last 25lbs?
Anyone have a trick for extending the range of a cheap torque wrench?
Old Jun 24, 2006 | 07:45 PM
densetsu's Avatar
dont over tighten with the torque wrench. if it goes to 150 then torque it to 150 and get a breaker bar and tighten it a little more with that, dont use your torque wrench to over tighten, they are very delicate and will function incorrectly if abused. also, you must always put a torque wrench back to zero when you are done using it or the calibration will be off, and dont ever loosen anything with it either... as for the axle nut, you will be fine, ive removed my axles a dozen times and i never use a torque wrench, well, unless my appendages have that function built into them by now...?
Old Jun 24, 2006 | 07:50 PM
xlr8r's Avatar
Cheers. I'll take it to 150 and then a little bit more w/ the breaker bar.
Old Jun 24, 2006 | 07:52 PM
densetsu's Avatar
you'll be good, just make sure you have someone press firmly on the brakes to make sure nothing spins slighty to absorb the force.
Old Jun 24, 2006 | 08:09 PM
TurTLe*'s Avatar
I don't think thats how it really works tho. standing on the bar. 175ft lbs isn't all too much. But yea just get 150lb and a maybe a 1/4 turn more with a breaker bar.
Old Jun 24, 2006 | 09:12 PM
kcryan's Avatar
autozone will loan you a bigger one for free....
Old Jun 25, 2006 | 09:26 AM
ThurzNite's Avatar
Don't forget one of those locking castle tops that you stick the pin through and prevent the nut from backing out.
Jae
Old Jun 25, 2006 | 09:33 AM
MaximaEvolution's Avatar
i dont think there are autozones on Cali.. otherwise..
haha
Old Jun 25, 2006 | 09:44 AM
MDeezy's Avatar
there must be some auto store with a loaner program. That will be much easier and better than trying to guess how much you tq'ing a bolt down. Especially when over tighning the axle nut could do damage to your wheel bearings.
or make a thread in the regional, certainly someone close to you has a tq wrench you could borrow for 5 mintues
Old Jun 25, 2006 | 11:22 AM
ThurzNite's Avatar
haha
They do. There's 1 down the street from me. Just went there last night to recycle motor oil.
Jae
Old Jun 25, 2006 | 12:44 PM
awsome.. get crackin homie!
Old Jun 25, 2006 | 06:15 PM
goldmax's Avatar
I wouldn't guess using your weight. Torque = force (your weight) x lever arm (distance ), so unless you got all your weight in exactly the right spot, you could overtighten it.
Old Jun 25, 2006 | 07:07 PM
densetsu's Avatar
not to mention that gravity (or force normal) exists perpindicular to the earth, thus your distance would vary depending on the angle of your personal force vector in relation to the pivot and F-sub N.
edit: we have exactly the same number of posts.
Old Jun 25, 2006 | 09:34 PM
ThurzNite's Avatar
174-231 lb/ft. Since when did everybody get **** about being accurate? What about those tire fools who use impact guns on your lugs? There are some people who believe you should be lubricating threads before tq'ing them for more accurate readings. Well, If you don't have the proper tool, get the right tool, or make do with whatcha got, knowing that you won't be factory spec.
Jae
Old Jun 26, 2006 | 03:27 AM
goldmax's Avatar
Exactly! Same number of posts plus we agree that gravity could be a major component in the calculation! http://forums.maxima.org/images/smilies/jump.gif
Old Jun 26, 2006 | 08:51 AM
96i30azn's Avatar
Get a 3 ft long leverage bar and a kitchen scale
Mar 12, 2020 12:06 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
dcam0326
Sep 18, 2015 04:52 PM
Hdnseek
Sep 9, 2015 05:55 AM
