5spd related question.Help needed!!
Old Jun 25, 2006 | 03:58 AM
99se5speed's Avatar
SHIFT_up
I went to my Mechanic yesterday to check on the rear engine seal that i replaced a little over a month ago and when he lifted the car i noticed some oil again. The oil is coming from around the shifter bushing area. The rear seal is OK and so are the axles. I've done a little research and i believe I've found the problem but am not to sure. From what i saw the oil is coming from the Striking rod oil seal. Does anyone know if this part is inexpensive and if this is the only thing can actually leak in that area? I searched pinnacle Nissan along with a few other sites like that and i wasn't able to find anything about this seal. I also checked out Napa and couldn't find it.
So I'm wondering if this is the part that's actually leaking (striking rod oil seal) and if this is the only thing can leak around the shifter bushing area. I suppose the dealer should have this right? Thanks for the help I'm a when it comes to standard shift.
P.S. I found a Steering gear & linkage seal kit maybe this is what i need? I'm totally lost.
Old Jun 25, 2006 | 12:23 PM
99se5speed's Avatar
SHIFT_up
Bump!!!!!!!
Old Jun 25, 2006 | 12:27 PM
i30ds's Avatar
Armed and Dangerous
If you checked BOTH differential oil seals then the strike rod oil seal is probably. It could be the o ring on your VSS though, but that is on the top of the differential so your tranny would have to be really full to be leaking there.
The part number is for the strike rod oil seal is 32858-03E00 which is 7.74 from pinnacle nissan.
Old Jun 25, 2006 | 12:30 PM
i30ds's Avatar
Armed and Dangerous
Also, go to the I30 section of the forum and go to the I30 5spd FSM sticky. That will show you how to replace the seal. Its pretty easy.
Old Jun 25, 2006 | 12:32 PM
99se5speed's Avatar
SHIFT_up
Cool, Thanks for the help. If anyone else can just clarify that it is the striking rod seal.
Edit: That part number doesn't come out as anything.
Old Jun 25, 2006 | 12:39 PM
i30ds's Avatar
Armed and Dangerous
The only one that can actually 100% verify that is the strike rod is you.
And that part number does come out as something just it type into their parts locator.
Old Jun 25, 2006 | 01:02 PM
99se5speed's Avatar
SHIFT_up
yeah my fault i found the seal on the site. Meh i'll order it anyway it's only 7 bucks. I guess now would be the time to get the urethane shifter bushing also.
Old Jul 17, 2006 | 08:13 AM
99max78210's Avatar
Ive had the same problem. At least I can take it back to my mechanic and have them fix it right.
Old Jul 17, 2006 | 08:46 AM
dgeesaman's Avatar
Maintenance Monster
Given how cheap the seal is, and that you can replace it on the car, I would start with that.
Dave
Old Jul 17, 2006 | 03:30 PM
99se5speed's Avatar
SHIFT_up
it's cool you guys brought up this thread again. I have an update.
So i changed the Striking rod oil seal with the boot. I also bought the urethane shifter bushing from Larrio here on the org. Everything feels wonderfull. The shifter bushing made a big difference, it feels more precise and i love the clicks it makes when you put it in gear. I also bought a razo shift **** today which weights 340grams (it's pretty damn heavy) but it's also a great investment. All i'm missing is the B&M STS which is coming soon.
Old Apr 27, 2007 | 08:28 AM
maxine'sMan's Avatar
Can anyone verify if there is a difference in part numbers for the driver side diff oil seal on a 93 for cars with limited slip and cars without limited slip? some parts places are saying that there is and they have different prices but the dealer is saying that there isn't..
Thanks in advance.
Old Apr 27, 2007 | 09:44 AM
dgeesaman's Avatar
Maintenance Monster
The oil seal on the driver side is different on the 4th gens. The VLSD oil seal is much larger.
Not sure about your '93'. If you provide a VIN I could pull the actual nissan part numbers. (PM is fine for the VIN)
Dave
Old Apr 27, 2007 | 10:34 AM
Dave, thanks a lot for your quick response. Due to increasing VIN scams I will not be sharing this information.. I'm sure you're not a scammer but I am very private with personal information on the web.
Is there no way to check without this information?
Thanks.
-Bob
Old Apr 27, 2007 | 07:56 PM
dgeesaman's Avatar
Maintenance Monster
Well the pn's I have for a VLSD M/T car are:
pass side: 38342-81X01
driver side: 38342-51E00
That's for cars with a build date of 07/91 to 05/95.
In this case it doesn't look like the VIN is necessary.
Dave
Old Apr 28, 2007 | 03:53 PM
thanks guys..
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
