Removing Front & Rear Bumper for painting???
Old Jul 2, 2006 | 07:50 PM
webking185's Avatar
check the how to's, but no comments on how to remove the front and rear bumper for painting? can some one let me know how to remove the front and rear bumper on a 98 max se? also, what steps will i have to do to remove the paint and fix the bumps? whats a good price for this at local auto body shop if they had to do it all vs. giving them the bumpers alone?
Old Jul 2, 2006 | 08:20 PM
DuMKuH's Avatar
You are better of leave the whole car for a day at body shop, than remove the bumpers, since you would have to remove taillights and unscrew about 6-8 bolts on the bottom plus a few clips, same for the front. If you want to paint it by yourself, you would have to sand it first with a rough paper, than go a little smoother, than put body filler on the spots you want to fix, then sand everything again to make it like one surface. Than put primer, and sanding again, from 220 grid to 1000/2000 wet snading. And only after that when you have smooth surface you can put the paint on. The painting in the shop would cost you 400-800 for both bumpers depending on the place.
Old Jul 2, 2006 | 09:24 PM
Black Maxima
It's not hard to do the front bumper. The only tools you should need is a 10mm socket with short extensions, philips/flat screwdrivers, and it would really be easy with a ratcheting wrench. Take grille out, headlights, look for bolts/nuts holding the bumper onto the car. There are three nuts on each side holding the sides of the bumper onto the fenders.
Old Jul 3, 2006 | 09:05 PM
Radek's Avatar
I wanted to have my rear bumper painted, the price was $400 and I would have to leave the car there for at least two days.
Old Jul 3, 2006 | 09:07 PM
Black Maxima
Riiiiiiiiiiiiiiip.
vingodine
45
May 21, 2016 12:46 PM
JoshG
21
Sep 4, 2015 09:04 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
maxipower
Aug 21, 2015 11:10 AM
