any electrical diagrams on bose audio
Old Jul 3, 2006 | 10:05 PM
kasemodz's Avatar
Anybody got any electrical diagarams of the bose audio online? I need them asap. Thanks.
Old Jul 4, 2006 | 06:07 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
How about adressing the problem first?
I'm confident any question you ask could be addressed without having to go through a wiring diagram.
Old Jul 4, 2006 | 10:09 AM
ThurzNite's Avatar
Can you be more specific? Do you need wiring diagrams of inside the bose headunit?
Jae
Old Jul 4, 2006 | 12:07 PM
chillin014's Avatar
yeah seirously, for a 99 cause i have no idea how to installl this fm modulator
Old Jul 4, 2006 | 01:34 PM
k3v's Avatar
k3v
duno if theres one online, but theres one in the haynes manual
Old Jul 4, 2006 | 05:21 PM
HomerMAC's Avatar
Donating i30 Owner
its an FM modulator why do u need wiring for this.. i thought hte whole reason u took this route was to avoid wiring..?
and you FSM has the best wiring diagram..
Old Jul 4, 2006 | 09:09 PM
darklegend06's Avatar
The 99's are totally different from the 95-96 and the 97-98. Even tho they are interchangable through out the years.
Old Jul 9, 2006 | 12:33 AM
kasemodz's Avatar
Well, basically from the other posts and friends, I have learned that the bose headunits pass low level signal to the amps and the amps amplify the sound in a nutshell. Well, a pc audio out also pass low level signal to speakers. Now, however, the amp require a (+) and(-) from the sin generator of the audio output. therefore I'll take some diodes, and make my own circuit so that the audio out from the computer splits into a y leading to a (+) and (-) audio signal. That hopefully should get decent audio to the speakers. Will keep you guys posted. Basically my plan is to put a carpc and use the same speakers and add a sub.
Fbana41
Aug 29, 2016 12:18 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
