maxima making some sound from back wheels
Old Jul 8, 2006 | 09:41 AM
indeep's Avatar
hey guys my maxima seems to be making some sound from this morning I went for a drive and it seems to be making some noise from the back like from the wheels I dont kno how to explain the noise kind of like a wobbling sound i dont know maybe the axel. It happened i think because my friend was doing burn out and he was driving crazy nyone know wat the problem can be and how much it will be to fix it?
Old Jul 8, 2006 | 10:10 AM
MrEous's Avatar
^ Jeff™
Check your brakes and also your parking brake...
Old Jul 10, 2006 | 10:50 AM
brd98maxima's Avatar
I had the same problem. It was the wheel bearing. It is called a sealed hub assembly. $122.50 at the stealership.
Old Jul 13, 2006 | 04:58 PM
indeep's Avatar
maxima
okk thanks
Old Aug 10, 2006 | 10:27 AM
ColinSick's Avatar
Spare tire could be loose -- just kidding
Old Aug 11, 2006 | 02:54 AM
aznxenon's Avatar
Mine is making noises too. Does it sound something like....eeeeeeeee chhhhhiiiiiiiiiiiii eeeeeeeee chiiiiiiiii?
Mine only make noise when the car is moving. When I lightly step on the brake, the noise goes away. When I left go of the brake, it comes back. But then, the noise only comes when I'm going about 0-30mph.
Old Aug 14, 2006 | 05:42 AM
h22enjen's Avatar
mine is doing the same thing on the driver side as well only when im moving slow. did u ever find out what the problem is aznxenon?
Old Aug 14, 2006 | 07:36 AM
96i30azn's Avatar
i had the same problem with front wheel. thought it was right, but a local shop put the car on a stand and ran it discovered it was left. i would put your car on jackstands and run the fronts to see if its them. it was LF wheel bearing btw
Old Aug 14, 2006 | 02:28 PM
aznxenon's Avatar
Well, for mine...somehow the rear left caliper was bent =X so only 3 of the wheels can spin freely.
So, my dad took it in the shop and replaced the rear 2 caliper. Cost - 112*2(parts) + 50(labor).
FanaticMadMax
Aug 10, 2015 08:55 PM
follyburr
Aug 7, 2015 09:50 PM
MikesChevelle
Aug 6, 2015 11:36 AM
Jcof88
Aug 3, 2015 10:43 PM
