USIM Question *pic*
Old Jul 10, 2006 | 01:19 PM
Fr33way™'s Avatar
Wild for Width
USIM Question *pic*
My '98 IM has this (circled in red) hose fitting right after the TB. I suppose the IM I have been working with is a '95 or '96. Is there a way to re-route this hose? I am guessing it is EGR related. Can I just vent it to the atmosphere or does it need vacuum to pull whatever gunk out?
I can get a picture of where the hose leads but it is a very close area.
Thanks for any help.
Old Jul 10, 2006 | 02:17 PM
speed racer's Avatar
does that connect into that brass tubing under the TB? I never seen that hose after the TB for 4th gen. Its probably a vacuum for your EGR like you said. I would cap both. It won't hurt the system.
Old Jul 10, 2006 | 03:37 PM
RA030726's Avatar
I'm nutty for Nissans
Its the vacuum referance, and you need it. See the small nipple just under the elbow on the one you want to put on. Thats the same thing, so just connect that line there. I can check both 96 and 98 IM diagrams if you need to know where that goes. I know the FPR the MAP use a vac source.
Old Jul 10, 2006 | 04:13 PM
RA030726's Avatar
i checked my 98 and that hose goes to all 3 emissions solenoids.
Old Jul 10, 2006 | 04:39 PM
matty's Avatar
where does the FPR get vaccum from ??
-matt
Old Jul 10, 2006 | 05:13 PM
RA030726's Avatar
On my 98 from the port below the large elbow, and I think all IM are that way.
Old Jul 10, 2006 | 05:15 PM
Fr33way™'s Avatar
Wild for Width
Thanks, that small one below the elbow is also on my '98 and in use. The hose goes down to an area where there are 3 similarly sized hoses all next to each other. I hope I can route this somehow as I am about 2/3 way through getting this IM ready to put on!
Old Jul 10, 2006 | 05:41 PM
Tatanko's Avatar
Bacon Lover
Just curious...how come you're swapping manifolds? Something different between the two (aside from the obvious stupid little year-to-year changes)? You seem excited for some reason
Old Jul 10, 2006 | 05:49 PM
RA030726's Avatar
He probably got a deal on one used and ported it.
Your going to have to tee off that 1 port for the vacuum gallery and FPR. Unless the bottom of your TB has a port on the IM side that sees vacuum when the TB is closed. Then you could route that one on top to the one underneath. I cant look at my TB seeing as I cut the bottom off.
Old Jul 10, 2006 | 06:00 PM
Fr33way™'s Avatar
Wild for Width
Possible to drill and drop in a nipple?
Old Jul 11, 2006 | 04:26 AM
RA030726's Avatar
yea get a threaded barb from the hardwear store. Then drill and tap a hole maybe JB weld that sucker in there.
Old Jul 11, 2006 | 09:40 AM
Fr33way™'s Avatar
Wild for Width
I think that is what I will do, thanks for the help.
Old Jul 11, 2006 | 09:46 AM
CreativeDesignz's Avatar
so what exactly did you do to this mani?
Old Jul 11, 2006 | 10:51 AM
Fr33way™'s Avatar
Wild for Width
I have been wanting to clean my IM and I came across this one so I cleaned it out and decided to remove the casting marks on the runners and the TB neck as well as polish them.
Old Jul 11, 2006 | 11:13 AM
sweet, got any pics?
Old Jul 11, 2006 | 11:40 AM
BigLou93SE's Avatar
subscribing...
Old Jul 11, 2006 | 06:34 PM
Fr33way™'s Avatar
Wild for Width
I may snap a few before I put it on.
Mar 12, 2020 12:06 AM
Pixel
Sep 15, 2015 05:53 AM
Krazzespiinz
Sep 13, 2015 07:10 AM
Johnny9595
Sep 3, 2015 05:18 AM
