Why do my brake still suck....
Yesterday i replaced the brakes up front with oem pads and new rotors... the car never stopped good before and it seems like the brake job didnt help...\
i have new fluid and i just bleed it... and i did the brake break in thing on this site http://www.zeckhausen.com/bedding_in_brakes.htm
and they still suck... i know ur supposed to give it some time before the pad settle but i have done the same procedure on many other cars and it worked....
Originally Posted by matty
Explain how they "suck" ??
Maybe you shoulda went with some Brembo Rotors and some aftermarket pads like some Axxis Ulimtates.
-matt
-matt
like i have to really press hard for the car to stop... there is almost no initial grab...
-matt
-matt
That's the set up that I have and I am very happy with it. They dust alot more than my wifes Raybestos Quiet Stop, but mine grab better.
-matt
-matt
anyway, you MAY have air in your system... in that case you would need to bleed the brakes again :-\
Man I have the same problem. New rotors and HAWK HPS pads (about 9 months ago they were new), proper bed in and complete bleeding a few times and I still have to press harder than I should to make it grab with any force at all. I know what you are going through. One day when I can afford to do something about it and I don't have a roommate that bounces checks and school to pay for I will just get a BBK and be done with it.
Maxima brakes just require a little more pushing ont he pedal to stop. I've driven 3 4th gens (owned 2) and they all require considederable effort to stop.
The new Maxima/Altima on the other hand stop on a dime.
the rotors are clean the calipers are not dragging... the booster seems to work like its supposed to.. i check the fsm and no problems there...im gonna bleed the master cylinder on sunday and see what happens.. i have driven tons of 4th gens and they stop on a dime not mine though
I experience the same thing as you describe the first few pumps after reinstalling pads and compressing the pistons, but it's always returned to normal.
Never had air in the system on this car, but I did on a Volvo. And since air can be compressed, it allowed the pedal to go to the floor.
Sounds like cheap pads. Next time get Hawk HP+ (Plus) if you want them to be grabby. They really bite, esp when they get warm/hot. When you modulate the pedal, it's either on, or off.
Jae
Jae
Jae
Jae
Whats wierd for me is that whenever I reverse I hear this sound in the rears like its not HOLDING or gripping the car. However during normal drive and braking everything is fine.
I wonder if its cuz I havne't bedded my pads in yet or broken them in. Again this sound is great only when I reverse.
Replaced my pads (weird sounds )then took a nice highway trip 70 miles hour break all the way down to 20mph or so go back to 60 or 70 and do the same break to 20mph 4 or 5 times.. early morning no one on highway though or your a sitting duck. next day the brakes are fantastic. Worked for me
There are only two ways to improve braking force. Improve the pads (higher friction) or a BBK (higher brake torque). Simply replacing components with equivalent parts won't do it.
Originally Posted by nart86
get some Axxis/PBR Ultimate pads from the GB on here and some new rotors.
i dunno i checked both the master cylinder and the booster and they both seem fine.. im gonna try to bleed the master cylinder by its self and see what happens..
maybe youre not putting enough fluid in?
I had some Hawk HPS pads put on my car... and they don't seem to stop any better than the Akebono pads that were on there before. In fact, I think I have to press the pedal harder just to get the same stopping power....
I can press the pedal really hard and still can't get the ABS to engage.
You know f550maranello2, I've been having the same problem forever... and never figured it out. My new rotors/pads/rebuilt calipers seems to help a little bit, but i want that initial grab! I remember driving another 4th gen and it bites hards! I've been stumped on this forever...
I've been wanting to change the master cylinder and seeing what happens... Also change the brake lines. I dont have ABS btw.
Now with 165k miles, i'm kindof like whatever... anyway. I hope someone knows the answer... If i ever figure this out... i'll post again! GOOD LUCK
^^^^ nope they are clean.. i have now put about 300 miles on them also.. they still suck.. i replaced my wheel bearings yesterday and checked up on the brakes.. they are wearing correctly but still they suck.. i dunno im gonna have to take it in and see what MIdas says.. this sucks
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
