5 speed shifting woes
Old Jul 18, 2006 | 11:01 AM
turboast4's Avatar
So after my beloved '87 bit the dust, I got a sweet 99. My first stick shift, everything seemed OK when I test drove it, but now there seems to be problems. Mainly the 1-2 shift can be rough. It's hard to make the shift, and if I shift too quickly, it feels like it's grinding. Those two were the only problems, with all the other shifts smooth. It feels like it's starting to do it a little for the 2-3 shift as well, but it could be my imagination. Everything else is ok, no problems going into 1st or reverse or anything, and the clutch isn't slipping.
Any ideas? Please help....
BTW, it's a 99SE Limited, 77k miles on the clock.
Old Jul 18, 2006 | 11:27 AM
wetzelman1's Avatar
get a new urettane shifter bushing. Or just wrap yours in duct tape.
Old Jul 18, 2006 | 12:35 PM
turboast4's Avatar
That's it??? Just bad shifter bushings?? Maybe an excuse to get a short-throw shifter....
Old Jul 18, 2006 | 01:52 PM
i30ds's Avatar
Armed and Dangerous
Synchros are going out.
Old Jul 18, 2006 | 01:55 PM
dgeesaman's Avatar
Maintenance Monster
Change the oil before condemning the synchros. It may help enough to avoid needing a rebuild.
I recommend Redline MT-90.
Dave
Old Jul 18, 2006 | 02:12 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
heck yea mt-90 FTW ! ive got 5 quarts in my basment better lock the door.....
Old Jul 18, 2006 | 08:51 PM
4x4Max's Avatar
does the duct tape plan actually work well???
Old Jul 18, 2006 | 09:29 PM
PLUMMAXSE's Avatar
Change the tranny oil, before you condemn it. Tranny oil possibly hasn't been changed in 77k miles!!
Old Jul 18, 2006 | 11:38 PM
96blkonblkse's Avatar
yep, try changing the fluid, if that doesnt help then it could be time for a new tranny.
Old Jul 19, 2006 | 05:18 AM
nismos14's Avatar
§è~® f®ÈÄk
Jeez, is it a grind or just a bit difficult to get into 2nd? If so thats normal. Just get used to rev-matching the 1-2 shift or slow down ur shifting.
Old Jul 19, 2006 | 06:42 AM
wetzelman1's Avatar
I'm pretty sure theres a sticky about it. I haven't done it but plan on doing it soon.
Old Jul 19, 2006 | 08:33 AM
4x4Max's Avatar
i looked and couldnt find it, sounds interesting though...let me know if you find it!
Old Jul 19, 2006 | 10:18 AM
turboast4's Avatar
Thats actually more like what I expected to hear, although it's unfortunate. I'll try the fluid change, maybe I'll get lucky. FWIW, a couple other guys I talked to said it might be the pressure plate, or possibly the pilot bearing. The amount of metal that shows up in the fluid should narrow it down a bit though.
Old Jul 19, 2006 | 12:26 PM
dgeesaman's Avatar
Maintenance Monster
The pilot bushing doesn't even touch the input shaft. Consider it nonexistant.
Old Jul 19, 2006 | 12:53 PM
southeast_first's Avatar
here's the link for wrapping the shifter bushing in duct tape. unfortunately the pictures don't work anymore.
http://forums.maxima.org/showthread.php?t=331517
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
hayne
Oct 5, 2015 11:53 AM
