B&M short shifter question
So I look everywhere on the net and nobody could answer me....
I want to know how much shorter is the B&M compared to OEM?
Originally Posted by NCSU_MAX
the height difference isnt huge but the throw is....... not sure of the exact measurements
Originally Posted by Apparition
hey NCSU I think it was Black Maxima that said in order to have a shorter shifter (in heighth) you have to chop it. Well I searched and didn't find anything so I was wondering how do you achieve this?.. not meaning tools, meaning methods.
You can do this, I did for awhile till I realized how ghetto the setup was and that it really wasnt a short shifter setup. But if you want to try it pull the **** of and go at it w/ a hacksaw. Start high on the shifter and work your way down bc you dont want to cut to much the first time. The shifter will obviously appear shorter but it will be notchy as hell and hard to get into certain gears sometimes, which Is why I went with the B&M.
You can cut the stock but it'll be really notchy and won't shorten the gears. You can also get another adjustable shifter like pacesetter which has a height adjustment and shortens the throws. But it'll also be very notchy. You bet bet is to get the B&M which is like 2-4 in shorter then stock.
Originally Posted by maxima_kid
Theres a pretty big difference. Also depends on what type of shift **** you get with it.
Mar 12, 2020 12:06 AM
