Removing snorkel, stuck at removing connectors
Old Jul 27, 2006 | 10:32 AM
itsdaveonline's Avatar
Ok if there were no wires attached to the snorkel i could eaisly get it off. How do i get those 2 connectors off the snorkel so i can remove it and clean the ****loads of dirt in it?
Old Jul 27, 2006 | 10:40 AM
Fr33way™'s Avatar
Wild for Width
Can you snap a pic?
I haven't had my snorkel on the car in awhile.
Old Jul 27, 2006 | 10:43 AM
Yeah sure i just walked out to the garage and realized that there was only one connector on the snorkel. But will it affect my performance at all? Pic is on the way ...
Old Jul 27, 2006 | 10:44 AM
Fr33way™'s Avatar
Wild for Width
Alright, I think you may be talking about the boost sensor (says this ON the sensor).
Old Jul 27, 2006 | 10:50 AM
i30ds's Avatar
Armed and Dangerous
Thats the ambient air temp. sensor in the snorkel. Just undo the connector to get the snorkel out of the car and then remove the sensor when you clean the snorkel.
Old Jul 27, 2006 | 11:05 AM
ok well heres the picture anyways its just the gray and green connector...
this is just a refference picture the connector is at the rear bend of the snorkel where the snorkel goes into the bottom of the airbox.
best pic of the connector
so i assume its the amb temp sensor, how do i d/c that damn connector its a ***** i have put some force into it but dont wana break it. Do i have to squeeze the green part down really hard then pull on it?
Old Jul 27, 2006 | 12:11 PM
Seriously can some one just tell me how to d/c the connector. It have been in the garage for 30 min pulling sqeezing trying to get this ***** ****er out of my car. edit: its the same style connector as the one on the top pic near the purple sticker.
Old Jul 27, 2006 | 12:37 PM
RA030726's Avatar
I'm nutty for Nissans
Push in on the green part and it will pop right off. Yet another reason to hate 99's.
Old Jul 27, 2006 | 12:41 PM
gtr_rider's Avatar
192.168.1.1
never understood why they used those stupid push tabs
Old Jul 27, 2006 | 12:49 PM
Ok well i tried that and the thing does not even budge ive been working on this for an hour now. im using my hands is this how ur supposed to do it?
Old Jul 27, 2006 | 12:56 PM
Omfg This ****ing Connector Will Not Come Off It Just Spins Around!
Old Jul 27, 2006 | 01:19 PM
i30ds's Avatar
Armed and Dangerous
Jeez dude its a connector. If the tab does not want to press in by hand use some pliers.
Old Jul 27, 2006 | 01:22 PM
Well here is the case now my connector by the purp sticker pops out with ease when its pushed inwards. But i did the same to the one on the snorkel and the green part does not ****ing pop out now its stuck poped in and the connector just moves around. I have tried plyers but my car has abs so its way to ****ing crowded.
Old Jul 27, 2006 | 01:25 PM
i30ds's Avatar
Armed and Dangerous
Take off the upper part of the intake between the air box and the throttle... then you would have a direct shot at the connector.
Old Jul 27, 2006 | 01:38 PM
I dont even know how to do that...... But the connector im working on is for sure broken, it does not function like the other one, when the green part is all the way poped inwards it still does not come out. I somehow maneged to get pliers in there and i am putting all of my bodywieght into this connector trying to rip it out but that stuburn mother ****ing thing is being a ***** i have 2 bloody fingers over nothing.
Old Jul 27, 2006 | 01:45 PM
See? the connector is pushed in and stuck when its puched in i tried using plyers out, the only result was some blood.
damn connector is the only thing stopping me from getting the ***** ****er outa here.
Old Jul 27, 2006 | 02:09 PM
well i guess im stuck going to the stealership.
Old Jul 27, 2006 | 02:46 PM
JwaxMax99's Avatar
Wait, don't go to the stealer. You guys have not had yours out lately.
On a 99, grab the connector and pull straight back, it will pop out of the snorkel. There is a rubber grommet holding it in.
No need to undo the connector.
Old Jul 27, 2006 | 03:45 PM
Gismo-T's Avatar
B!tch We Got a Problem
Ya, no need to disconnect the connector, just pull out of grommet. I'f you disconnect your sel will go on! Then you'll have to reset the ECU!
Zip tie the sensor behind the filter if you plan on putting a cone filter on.
Old Jul 27, 2006 | 07:12 PM
oooooo so just pull on the entire connector kinda hard and it should come out with the rubber gromet? Will my car perform the same with this thing out? Thanks x1000 for this advice!
Also i dont think that the conector was d/c at any point but how do i tell if my "sel" is on, what the hell is sel? thanks!
Old Jul 27, 2006 | 07:42 PM
Gismo-T's Avatar
Are you just removing the snorkel to clean it & put it back on, or are you going to put a cone filter in its place?
SEL-service engine light or CEL-check engine light
Old Jul 27, 2006 | 07:56 PM
JwaxMax99's Avatar
Yes, but...the grommet stays in the snorkel.
Old Jul 27, 2006 | 07:58 PM
oh ok well that is about it thanx all!
Old Jul 28, 2006 | 10:04 AM
ok well this is the ****ing gayest thing i have ever done i am using all my mucle to pull this ****ing connector out and it STILL will not ****ing come out WHAT AM I DOING WRONG?
Old Jul 28, 2006 | 10:11 AM
What The ****!
Old Jul 28, 2006 | 10:23 AM
can somebody tell me how to take off the uper part of the intake? i have no ****ing clue how to do so. SOMEBODY HELP ME!!
Old Jul 28, 2006 | 10:28 AM
JwaxMax99's Avatar
Get to the gym....
Old Jul 28, 2006 | 10:31 AM
Uh well i can only fit one hand in there....I seriously need ****ing help someone........
Old Jul 28, 2006 | 10:42 AM
i30ds's Avatar
Armed and Dangerous
Did you even try to remove the intake between the throttle and the air box?!?
Old Jul 28, 2006 | 10:51 AM
yes ive tried that, i removed the 4 golden screws that go into the airbox and i dont have the right tool to remove the last nut holding on the plastic down, i dont have a deep socket or an extention. So i guess im screwed.
i cant reach that nut down there
Old Jul 28, 2006 | 11:22 AM
i30ds's Avatar
Armed and Dangerous
Maybe you should not work on your car unless you have a proper tool set.
Old Jul 28, 2006 | 11:28 AM
Whatever im gona get it done at the $tealership nobody really seems to be helping.
Old Jul 28, 2006 | 12:01 PM
i30ds's Avatar
Armed and Dangerous
Its definately NOT a lack of help. Everybody helped as much as they could. The real problem is that you don't seem too mechanically inclined and you don't even have the tools to work on your car. Most people here would have had that connector off and the snorkel removed in a matter of minutes.
Old Jul 28, 2006 | 12:12 PM
I had my one of my friends try to pull this thing off, he can bench over 180+ which is not uber strong but it should be enough to get a connector of right? wrong, this damn donnector is offically stuck on. The snorkel is from a junkyard and is not exactly in the best condition and is most likely not from a 99. i have tried evreything on this thing. all the other connctors on the car work and eaisly come off and require little or no effort.
Old Jul 28, 2006 | 06:26 PM
Fr33way™'s Avatar
Wild for Width
Keep going! Pics of said blood.
Old Jul 28, 2006 | 08:35 PM
Its just a couple of bandaids no pics
Old Jul 28, 2006 | 08:57 PM
gtr_rider's Avatar
192.168.1.1
you gotta be kidding me..?
Old Jul 28, 2006 | 10:24 PM
96blkonblkse's Avatar
dude fawk it, rip it off, your tellin me a piece of plastic is overpowering a man? a man with hoepfully lots of tools that should easily take care of it. Try pulling as hard as you can, put gloves on so you dont fawk your hands up if it comes out, and rip that SOB out.
Old Jul 29, 2006 | 07:05 AM
sportbikenut's Avatar
Airbox hose??
Pretty funny post above. Was he joking??
Question. Can someone direct me to where a pic is located that shows the other side of the snokel airbox (compared to pic earlier in this thread). A little nipple sticks out and appears that it should have a vacuum line attached. Can't find the hose. Where does it go?
I just finished replacing my EGR Valve and Knock sensor (w/o removing intake) and no bloody knuckles either!
Thanks.
Old Jul 29, 2006 | 07:07 AM
FYI - Search?
I am asking because apparently I do not have access to the "Search" function. Or do I? Where is it? Thanks again.
